error code 52 fixed!!!
hello everyone, first i would like to say thank you to all who post to this site. when i needed insight into this error code 52 this is the site i looked to for help and it paid off. throughout my search i concluded that only three things can cause this code to appear
1- the knock sensor is bad
2-the wired connection from the KS to the ECM is bad
3- the ECM is bad
thats it only three things, why? because its a closed circuit wire comes from sensor and straight to the ECM.
my problem began when i changed the head gasket on my 3.0. when i started up the engine again this code came up.
for me i determined that since i did not touch the KS or ECM and my battery was out during the dissemble the only thing it could be is the wire, since i unplugged it form the the KS. on this site i found out the most common wire section to fail is the one coming out alongside the intake. so i went to toyota and $19 later i had a new wire(they even had it in stock the part manager said it a common issue, he also asked if i had removed the KS because his experience is that they sometimes fail once removed????).
it took me 6 hrs to change out the wire and it worked. my 4runner is off and running better then ever
so remember if you have this issue it can only be these three things so diagnose people and good luck,
IT CAN BE FIXED....ITS A TOYOTA!!!!!!
3- the ECM is bad
I agree that the total cost of repair was low, but if they're marking up a wiring pigtail that much extra, imagine what they're doing to other parts! I have a very good relationship with my local dealer, and I get those wiring pigtails for $9/ea out the door. (price just went up from $8.xx)
I'm just saying, you can dicker with them on prices. Often times they'll give you a discount just for trying. Nothing is set in stone unless you're willing to just pay the price, in which case it gives that illusion.
Thanks
Repo
No problem! Worked for me, now I get most things at or just above dealer cost. Been going to the same parts guys for seven or eight years now. When I call, they know it's me and allow me to order parts over the phone, even special order stuff, without giving credit card info. They just tell me when to pick it up.
I always make sure to let their manager know how helpful they are, and that they always go out of their way to make sure I'm a happy customer, and find difficult to locate parts for me.
i didn't know you could bargain a bit with them... good to know for the next time, thanks. that was the first time i went to the dealer for anything, i typically stick with auto zone and my local junk yard. it was just that with this part autozone didn't carry it and i didn't want to get a used one, due to all the labor i was putting into to the repair.
thank you all for the insight.
3- the ECM is bad
3- the ECM is bad
I had the same problem as this, and I checked and found fault number 52.. I mean, I need to remove the engine heads and say to change the sensor wire, the strokes only? Will the car be in the best performance? Wait for a reply from you immediately if you can
montanatruck
02-26-2017 07:07 AM
