engine stumbles while driving..
Old 02-12-2008, 03:57 PM
"pete f passed away quietly in his sleep on July 13, 2008
pete f's Avatar
Originally Posted by chugs
alright, i'm having trouble determining what codes i'm getting...here are my read outs, getting 2 flashes, then there is a 2-3 sec delay...flashes 4 times...and another 3-4 sec delay....flashes 3 times....2-3 sec delay..and 2 flashes...what do u think it is?
Your getting a Code 24 and a Code32.It is probably your VAF(Volume Air flow). I would get some cleaner and give it a good cleaning.http://personal.utulsa.edu/~nathan-b...33volumeai.pdf
I would search VAF here to see the do's and don't.Make sure you undo the connection by prying off the thin steel wire that secures the plug.What ever you do DON"T unscrew the two screws on the plug.Also check the link I gave you on the codes.While you are at it replace your air cleaner.
Old 02-12-2008, 04:53 PM
chugs's Avatar
i have a drop in k&n filter and i just cleaned it the other day, along with the isr mod, i've had this setup installed over a year now.....i'll have to check to see if there are any air leaks in my intake tube...
Old 02-12-2008, 05:52 PM
pete f's Avatar
I hope you get it.Sometimes it takes a little time and effort but it all worth it in the end.I'm standing by .Be sure and post!!
Old 02-13-2008, 01:02 PM
chugs's Avatar
well, i checked the intake system, vaf was clean, intake tubes were not damage or leaking air....i disconnected the battery to reset the computer and i'm not gettin any codes now....i'm just getting steady flashes....so I will drive it how it is for now to see if the problem reoccurs and I will check the codes again tomorrow...
Old 02-13-2008, 01:46 PM
  #25
chugs's Avatar
i guess i don't have to wait until tomorrow to check the codes, as i was about to leave the house, i started the engine and as before, rpms drop, engine struggles to maintain idle speed, and shuts off. Checked the codes and still getting the same codes 24 and 32. I guess i have it narrowed down to the vaf, will be looking to replace it.
Old 02-13-2008, 04:13 PM
  #26
pete f's Avatar
Maybe it is just the sensor. Did you check the resistance on the sensor?
Old 02-13-2008, 08:44 PM
  #27
chugs's Avatar
i will check the resistance prior to replacing it...will keep u posted
Old 02-19-2008, 03:41 PM
  #28
chugs's Avatar
It appears vafm was bad, i replaced it with another one, reset the computer, drove it around for a while and i am no longer getting any stumbling engine issues or loss of power. I checked the diagnositic codes and I am getting just the flashing cel. So if any of you guys who have the 3.0 and run into a similiar probelm and get codes 32 and 24 it is more than likely the vafm. Thanks a lot pete_f for the help.
Old 02-19-2008, 04:23 PM
  #29
pete f's Avatar
Congrats Chugs ...You are the man
I get a great feeling just to help a little.Way to go.
pete f
icentropy
09-16-2020 02:47 PM
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
jasonty
41
12-23-2018 01:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
Quick Reply: engine stumbles while driving..
