Engine rebuild
Old 09-04-2008, 12:25 PM
95_4MuddinSr5's Avatar
Engine rebuild
Blew my heag gasket and now im going to get it rebuilt. Im going to remove it myself, and was wondering what a full run of the mill rebuild on the 3VZ-E should cost? Whats the best route to go on this particular situation? Self rebuild? I need advice!! And rough price estimates?!!?
oh and if anyone want the truck as is. its for sale. 2800.
Old 09-04-2008, 05:53 PM
Anyone with advice? Anybody?
Old 09-04-2008, 05:57 PM
Dan.3's Avatar
how much is the rebuild kit?
Old 09-04-2008, 06:04 PM
thats what im wondering. i cant find a solid rebuild kit and cant find a solid price for somone else to do a complete rebuild.
Old 09-04-2008, 08:05 PM
RobD's Avatar
Pull it out, drop it off a cliff and swap a 3.4.
If you can pull a 3.0 out and rebuild it yourself, you can do an engine swap. The 3.4 is a way better engine, with fewer problems, more power, and better fuel economy.
Old 09-04-2008, 09:45 PM
scuba's Avatar
Knew that was coming
Old 09-04-2008, 10:21 PM
space-junk's Avatar
www.engbldr.com
im pretty sure that there is parts for a rebuild kit available...
depending on what you want to do to the motor, could cost up to 3 grand... 1200 just for the headgaskets... if you have a shop do it...
Old 09-05-2008, 04:14 AM
RobD's Avatar
If you knew it was coming, then you should also understand the reasons why.
Old 09-05-2008, 07:26 AM
canadianmat's Avatar
Well i had the same problem 2 weeks ago, blewn head gasket then decided its way too much work to just patch so i started hunting for parts. I found an awesome deal on GOOD parts from japan engines on ebay. For peace of mind i bought every part inside the engine, from timing belt and idlers to pistons and rings even the heads all new with no core charge for $1200 delivered to my door. I live in canada so im sure my shipping cost are higher than yours will be. I was confident that i would only have to get the pistons hung on the rods by someone else, and i did my own honing so in the long run about $1400 and the engine is new!
If you dont have any experience with rebuilding engines maybe look at the rebuilt long block route, there are some good deals on those on ebay as well for about $1595, one place in oregon warranties for the life of the truck as long as you own it. Don't know what its worth but it sounds good. Good luck!
Old 09-05-2008, 07:37 AM
cutboggers's Avatar
uhh top of page has an ad.
You honed your own cylinders but couldn't hang the pistons?
Our the press fit or sumthing?
Old 09-05-2008, 07:42 AM
Yes 3vz pistons are press fit, 22r are c clip style "floating". I was tempted to do my own but the thought of bending a rod or over heating it when reinstaling the pins back in made me nervous. There is a video on you tube that shows the whole process http://www.youtube.com/watch?v=H2YrL3k__dA check it out.
Old 09-05-2008, 07:44 AM
cutboggers's Avatar
sweet
Old 09-05-2008, 11:22 AM
Broomie's's Avatar
Here in Arkansas,you can't give a 4runner with a blown 3vz-e motor away, let alone sell it for more than $500 bucks. I'm with RobD,pull it and drop it. If you are going to keep the truck then go with a warranty motor from some motor builder, because unless you really know what you are doing, the 3vz-e can be a real motherf!@#$%. And when you get it built it can break about as fast as you can look at it. They are the kind of motor that if you have a good one it would last a long time, but when they go bad there tost.
Old 09-05-2008, 12:04 PM
forbiddenera's Avatar
that's like the 30th time ive read that this week
and im still tempted even though im half done my hg fix
someone find me a cheap donor
Old 09-05-2008, 12:30 PM
mike92runnerSR5's Avatar
I bought my rebuild from import engine specialties. He has a listing on ebay right now. Quality job, good service and good waurantee. My mechanic was very impressed with the quality. Been 14 months and 4k miles running great. Speak to Mark.
bigjstang
08-25-2021 12:41 AM
jerusry
10-19-2015 05:28 PM
Yota.Jay
07-23-2015 08:08 PM
God's Bounty Hunter
07-08-2015 12:54 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Engine rebuild
