Engine Hesitation, whats happening?
Running fine, then pulled off to have some fun in the mud, pretty bumpy (harsh bumps) and a few puddles. Played for about 3min, then pulled back on road. Now the truck hesitates when under any more load than about half throttle. I got on the freeway fine, felt a little less power. It would get up to speed fine and hold any rpm smoothly, but when i push the throttle down, i'd feel some jerkiness to the acceleration. Every now ant then it would cut out and drop the rpm 300-400 then return to normal. Definitely only under load. Seemed to have gotten slightly better after 10min, but still there. I popped the hood and nothing really got wet, distributor/filter/wires all stayed dry.
What the heck is going on??
feels worst when starting out in first gear, then its fine for the rest of first, also when at a low speed but in a high gear so its kinda lugging, hesitates badly.
not water in filter, i checked and it was completely dry. next morning, not quite as bad, but still hesitating bigtime. I was able to make a 200 trip home so any water anywhere had to be evaporated. still doing it. worse when cold.
i picked up a cap/rotor, plugs, fuel filter, air filter, and some seafoam. i'll give all that a whirl tomorrow morning and see what happens.
well, changed the plugs/cap/rotor and that seemed to fix it. rotor was pretty fugly, i just don't understand what happened to make it hesitate all of the sudden. oh well, problem solved.
Could have just been a coincidince....
I was out wheeling one day, and at the same time my exhaust wraped around my axle, and my cap/rotor melted. I thought it wouldnt start because of the exhaust being clamped shut, so I had my buddy pull it straight with his truck and removed it at the cat...still wouldnt start. Started playing around, I was getting fuel, and no spark.. So I took the cap off, FUGLY... It was just weird that I did both at the same time.
TURBOrunnerNM
07-22-2015 11:01 AM
jon.r
07-11-2015 03:34 PM
88runnergomas
07-09-2015 01:12 PM
