eliminating cat & muffler
Old 04-14-2010, 12:25 PM
516593812's Avatar
How loud would my truck be if i replaced the cat & muffler with a straight pipe? I was originally thinking of removing the cat, but after further consideration i'm thinking i want to cut the exhaust off right before the cat, replace it with a pipe that would be about the same length as the original one. I figure when i need to get it smogged again, I'll just clamp the whole setup back on. My main concern at this point is the loudness- would it be nice & rumbly, or unbearably loud? Any input as to how loud (decibals?) this setup would be?
Old 04-14-2010, 12:53 PM
b0n3mast3r's Avatar
super loud as of rite now im running staright header
Old 04-14-2010, 01:15 PM
Philbert's Avatar
I ran a straight LCE header for a few weeks until I had the time to install the rest of my new exhaust - it sounded like a V8! Fine at idle, but any gas and WOW it was loud.
1) probalby illegal due to noise (and you may get ticketed for not having a CAT if they pull you over for noise)
2) If you let your CAT 'sit' in between smogs, it could "go bad" - be careful there.
Old 04-14-2010, 01:16 PM
allnmstkn313's Avatar
Very loud, and not very funny if you get caught without it
Spend the cash and do it properly
Old 04-14-2010, 01:18 PM
BackGateYota92's Avatar
dont know about the 22re but the 3.0 is extremely loud unhooked
Old 04-14-2010, 01:58 PM
516593812's Avatar
how about if i left the cat & eliminated the muffler? (replacing it with a straight pipe)- would the cat muffle it enough to not attract cops- i definitely don't want it crazy loud
Old 04-14-2010, 02:18 PM
JamesD's Avatar
Still loud. If your state has a visual then hog out the cat and put in an aftermarket muffler to save some money. I used a 3 chamber Flowmaster on my 22R. It is on the loud side but quieter than no muffler. Also you can buy the Ebay replacement cats for cheap like under $70 and almost all of the cats are free flowing anyways.
James
Old 04-14-2010, 02:26 PM
why dont you spend a lil money and do it right the first time? a magnaflow hi flow cat is 60-70 bucks and a muffler of your choice is 20-100 depending on what ya get. alot cheaper than the tickets you will be getting. lol
Old 04-14-2010, 02:31 PM
516593812's Avatar
i didn't know they were that cheap- i just looked & can get a chamber type muffler (cherry bomb brand) for about $25 new from Summit Racing. My issue is that if i spend money on it & "do it right" i want it to be smog legal- i don't want to spend money on a cat & muffler,spend time installing them, then have to re-do it come smog time 'cuz they won't pass- so will these "high flow" cats & an aftermarket muffler (like the one i'm looking at) pass smog in WA?
Old 04-14-2010, 02:36 PM
yotaman85's Avatar
all magnaflow cats are legal in WA. in fact they are legal in all states except california.
yotaman85's Avatar
and a muffler will not effect smog. you do not need one if you want it loud.
Old 04-14-2010, 02:42 PM
turboturd8607's Avatar
even with the cat it will still be unreal loud. if you want loud but not too loud keep the cat and get a glasspack.
Old 04-14-2010, 02:51 PM
man look into the cherry bomb extreme if your lokking into cherry bomb muffler. i love mine and cant say enough bout it
Old 04-16-2010, 07:45 AM
516593812's Avatar
So if i remove the cat & just keep it in my garage untill emissions test time, can it go bad? is there any truth to this? if so, is there a particular way i can store it so that it doesn't go bad after a year or so? also, how would i clean it when i wanted to put it back on? how about a seafoam treatment?
Old 04-16-2010, 07:49 AM
MaK92-4RnR's Avatar
from personal experience, keep the muffler. otherwise you're gonna have a tractor, not a toyota.
Old 04-16-2010, 08:02 AM
516593812's Avatar
i'll keep the muffler, it's in really good shape. but i do plan on cutting out the cat, replacing it with a pipe, & just using exhaust clamps with bolts so it will be easily bolted back on come emission time (i did this with my previosu truck-'90 2wd 22r PU & it make a noticeable difference in smoothness, power & sound)
my question is: can the cat go bad if it sits in my garage for a year? i heard they can stop "catalyzing" (yes that's a real word) if not in use for extended periods of time
Old 04-16-2010, 08:05 AM
poynter's Avatar
What do you do with your your 02 sensor when removing the cat and downpipe?
Old 04-16-2010, 08:11 AM
MaK92-4RnR's Avatar
keep the O2 sensor, and remove the catalytic converter. its what i did, sounded really nice through a borla muffler.
Old 04-16-2010, 01:52 PM
516593812's Avatar
anyone?
Old 04-16-2010, 04:14 PM
hunter4runner's Avatar
how long do you think cats sit on shelves before they are bought?
it shouldn't be an issue, cats are platinum mesh around a ceramic brick, its not an issue
Quick Reply: eliminating cat & muffler
