EGR code 71
Old 10-10-2007, 07:27 PM
Snorkeldepth's Avatar
Search "code 71" and you'll find two threads I started and a whole lot more!
Good luck!
Old 10-10-2007, 07:36 PM
naadomail's Avatar
I like the resistor idea. And I saw a picture of it in practice, but I have no idea where to pick one up...Help?
Old 10-11-2007, 07:32 AM
n4ynu1010's Avatar
Egr
I will see if I can find the thread again , from what I remember it is a 10 ohm resistor you just solder between the 2 Temp Sensor wires , you can get a resistor at radio shack , MudHippy knows about the place to get as he is the one that listed the aftermarket supplier in one of his threads , maybe he will check this out and tell you , otherwise I will look and see if I can find , do a search on EGR or Temp Sensor and see what you get . It was a EGR Thread I believe he gave the reference
Old 10-11-2007, 12:47 PM
MudHippy's Avatar
Radio Shack.
Never done it myself, but see this post https://www.yotatech.com/50443138-post31.html from this thread https://www.yotatech.com/forums/f116...my-egr-108005/. Post #9 also explains the details of the blocking off technique.
Old 10-11-2007, 02:44 PM
  #25
n4ynu1010's Avatar
Egr
Get you the resistor ( 10K ) , small shrink tubing pack and a tiny roll of solder :
Solder those wires shrink tube each side up to the resistor and then slide that larger piece you put on before soldering the ends and shrink that then use one of those clips on your firewall and tuck it in and no more blinking toture .
Old 10-11-2007, 04:57 PM
  #26
Guardian_Saint's Avatar
I have alot of resistor, if you need them all you have to do is PM me for it, just send me a dollar just for the shipping and you can have 5 resister...
Old 10-12-2007, 08:36 AM
  #27
n4ynu1010's Avatar
Motor Differences
Originally Posted by Vohaul
hey,
not to hijack the thread or anything...but thanks for that link..ive been looking forever for a link like that...
does anyone know if theres much difference btween a 91 truck and a 93....
From what I have seen the only major differences are the emissions packages on them , the FSM lists them all , just have to identify what you have (type of EGR ,PCV,EVAP) and then you can go from there.
Old 02-12-2008, 05:29 AM
  #28
Victor's Avatar
WTF? Engrish prease. Since you are installing into a female connector couldn't you just bend the ends and slip them into the connector? Or are your instructions to cut the wire, solder, and use heat shrink tubing?
I've checked my whole EGR system for vacuum leaks, replaced the EGR valve, and that damn code came back on again. I want to just put the resistor in and be done with it. I know the valve is working properly - it has to be that temp sensor coming out of the valve that must be sending a bad signal. I could replace that but at $150 and the cost that I'm in on the EGR valve it would be pointless. BTW - anybody want a perfectly good used EGR? I'll sell it off cheap.
Old 02-18-2008, 08:59 AM
  #29
Victor's Avatar
10K resistor worked like a champ. I didn't pull the battery to reset the code - the light turned off after a couple of errands and hasn't been back. Now I just have to figure out if I blew the fuse for my clock.
splangeland
04-06-2024 08:14 PM
some drunk guy
08-03-2021 06:09 PM
accuracy
09-20-2015 07:44 PM
Armstrong486
09-19-2015 12:37 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: EGR code 71
