e-locker questions
Old 10-27-2010, 10:00 PM
JonnyBoy's Avatar
Ok, just to clear some air, any v6 8" ring & pinion will work in the 8" E locker housing. I can't help you exactly on the wiring, I paid for a switch and harness, but there is a way to wire it in without relays. The kit I got just has wires to a toggle switch, although there's several connections on the back of the switch. You'd have to wire in the sensor that tells the motor when to stop so it doesn't continuously try to lock/unlock it. I believe the 4x4wire link has the particulars of making your own switch, if not there's info out there if you search google or something.
Old 10-30-2010, 08:00 AM
Duffdog's Avatar
yes, you can totally use a momentary switch like you were thinking for the actuate/de-actuate motor. If it was me, I would use two relays and wire them "reversing polarity" to make the motor work.
heres how:
http://www.the12volt.com/doorlocks/page3.asp
06-01-2021 01:51 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: e-locker questions
