Drove over a ledge - Sudden, Extremely Loud, Engine Tapping (& timing parts question)
Old 06-23-2009, 05:10 PM
jungle_runner's Avatar
Red face Drove over a ledge - Sudden, Extremely Loud, Engine Tapping (& timing parts question)
i've had minor tapping for about a year ... i drove over a 4 foot grass divider in a parking lot, not realizing that there was a 3 foot, concrete drop-off on the other side!
the rear frame got hung up on the concrete lip and i had to lock in the front wheels because the rear ones were hanging off the ground you should have seen the way people were staring at me ... "yes, i'm a little crazy, i already know this, but yes, this is a little embarrassing" was going through my head ... anyway ...
i got the truck free and continued running errands around town, third time i turned the engine back on, extremely loud tapping, speed of tapping associated with engine RPM, not vehicle speed
pulled the valve cover today and i see worn notches in the middle of the rockers ( i always thought the screws were the highest point and would be hitting the cover ) ... anyhow ... their are no notches in front rockers, they start showing on middle rockers and get deeper towards the rear of truck
Do you think the cover got jarred downward and compressed more? The whole rail was jarred? Or the rockers themselves?
I figure the engine is one unit that moves together on the mounts so i'm surprised that the jolt may have triggered the noise. Could it be something else I'm overlooking?
Also, while I'm in there, going to redo timing parts. Do people use the terms "timing dampers"/"timing guides" interchangeably? Had some confusion when calling around for parts. Know a place in So. Cal that I can pick up metal guides in-store?
Thanks a bunch, rock on!
Old 06-23-2009, 05:12 PM
i should add that when driving after the loud tapping started, i had to give engine a little gas at stops to keep it running or it would stall
Old 06-23-2009, 05:26 PM
yoterr's Avatar
might have busted those worn out timing guides and the chain jumped a tooth? tapping noise would be the chain slapping the timing cover and the idleing rough would be the engine out of time? just a thought
Old 06-23-2009, 05:45 PM
yoterr, thank you for the reply
yes, looked at the guides/dampers, still not sure if they are sometimes called dampers as well ... they look broken when looking down on them with timing cover still on
In-store Metal Timing Guides in Southern California!?!?! Anyone!?!?! Know a place?!?!
guy on the phone at autozone said, metal guides are louder.
ha!! it's all about utility, not luxury ... i have the top off most of the time anyway
Old 06-23-2009, 05:59 PM
iamsuperbleeder's Avatar
The guy at AutoZone is a tard, because they probable can't get steel guides to begin with
I HIGHLY doubt you'll be able to get steel guides anywhere over the counter, unless engnblr or LCE is in the neighborhood
You can get the kits online easily. I'm installed the engnblr kit with my 22re rebuild, that has a steel DRIVER'S side guide only, as they are most common to break, and that's the side that the chain can ware into the water pump housing. Also, the guide is steel, but is rubber coated, so it's not doing to make any more noise than an OEM plastic one, untill the rubber wares off anyway
As far as the names, most will just call the 2 side plastic rails that the chain runs against the guides, and the spring loaded thing at the bottom that presses on the chain to keep it tought the tensioner
Before I tore down my engine, I had an obvious brakage with my driver's side guid:
the new kit from engnbldr consisted of both sprockets (cam and crank), the chain, the tensioner, both guides (as well as new bolts for the guides), timing cover gaskets, and a new front main seal:
Now LCE offers a kit as well, that looks like both the guides are metal; bare metal at that; no rubber coatings on these guides... it's also a little more pricy, but that's cause it bares the LCE name
Also, I think the dropping off the ledge and this happening is probably coensidence but just maybe the jar was all it needed to make the guide fall apart the rest of the way. Once my guide and tensioner failed, I developed a HORRIBLE as well, so it's very possible this is your problem
Old 06-23-2009, 06:26 PM
iamsuperbleeder, you're the best! thanks for taking the time to write this up AND post some awesome photos! you
that photo of the broken guide vs the new ones on the engine really made it clear to me that they are in fact broken ... i am going to order the LCE or engnbldr kit and support the guys who support us ... thank you again
Old 06-23-2009, 06:31 PM
no problem buddy; we do what we can
Old 07-03-2009, 02:20 PM
i just finished rebuilding the front end and started up the engine ... still the loud tapping sound ... i took the valve cover off (knowing that oil would spray every where) and started the engine again because i wanted to be sure it wasn't a rocker hitting the cover ... still the same noise
it sounds like the noise is coming from the rocker assembly near the rear of the engine
do you think i need to rebuild the cam shaft/rocker assembly? could it be a valve? any ideas on how to deduce where the problem is coming from? i can't keep the engine running for more than a few seconds because of the oil spray
thanks
Old 07-03-2009, 02:26 PM
abecedarian's Avatar
any chance that getting hung up caused the exhaust to get damaged, maybe a broken manifold stud at the rear of the head?
it is a loud tapping like sound, and not a harder 'knock', right?
Old 07-03-2009, 02:32 PM
hmmm ... i thought about that ... that it could be exhaust ... but the noise seems more like metallic tapping ... but i will go check that right now ... thanks abecedarian
Old 07-03-2009, 02:36 PM
an exhaust leak around the exhaust port can sound like someone tapping on a thin piece of sheet metal with the tip of a long screwdriver or pencil tip
Old 07-03-2009, 03:23 PM
ok, i checked the exhaust from the block to the cat and every looks ok
i just took some video of the engine running and will post once i finish processing it
also, the engine dies even though the idle is strong and smooth, it's like there is some resistance somewhere
once again, still does it with the valve cover off
i'm thinking that it may be down near the flywheel now
thanks for the replies everyone, i would love to get this fixed tonight so that i can finally go home, and be back for the holiday weekend
Old 07-03-2009, 03:54 PM
Video Posted
Video of loud tapping noise with engine running (does the same thing with valve cover removed):
[YOUTUBE]http://www.youtube.com/watch?v=Eaf_siHHrD4[/YOUTUBE]
Old 07-03-2009, 04:26 PM
ok, now i'm kind of thinking that it is an exhaust leak because i see exhaust coming out near the manifold
would the lack of back pressure cause the engine to die when at low idle?
thanks
Old 07-03-2009, 04:54 PM
dutchboy's Avatar
This sounds like one of my farm tractors...with an exhaust leak.
Hmmm...
Old 07-03-2009, 05:10 PM
yep, definitely an exhaust leak ... i tighten up the bolts near the rear of the exhaust manifold and the noise has dramatically reduced ... wow! now i know (and you know (for the other noobs)) what an exhaust leak can sound like, thanks every one
i still would like to know if an exhaust leak (not having enough back pressure) would cause the engine to die? ... i just want to be sure that this is what is probably causing that to happen ... my intuition says yes, but i'd like a second opinion
thanks
Old 07-03-2009, 07:02 PM
overall, no, an exhaust leak won't cause the engine to die.
but since you've had valve cover issues, I'd venture enough to guess that you've got a leak around the valve cover causing a rather large vacuum leak (no, don't go reading the 'oil cap removed' thread... ). since the PCV system requires a sealed crank case to operate properly, if the valve cover isn't sealed properly it will present itself as a major vacuum leak and can cause engine driveability issues such as stalling at idle and lean mixtures.
Old 07-04-2009, 03:18 AM
it's 4am, i've been working on my truck since 11am this morning and have been putting in 6 or more hours every day for the last week ... i really need to get this done ... here's the update:
ran to autozone and picked up a new manifold gasket, flange rings, and the red silicone sealant ... even though one bolt into the head seems to be stripped, the exhaust leak is now audibly gone, no tapping noise ... i figure that the jolt to the frame on the concrete broke loose the gasket's seal on the manifold ... upon inspection, it was a very old, cracked gasket
i probably mentioned before that the timing guides were broken as well (don't know how long that had been broken or if it happened at the same time as the exhaust leak), so new guides, chain, gears, tensioner, and gaskets have all been installed
the engine started stalling at idle as soon as the exhaust leak started making it's noise, but now, with the exhaust leak fixed, the engine is still stalling at idle and sputtering at higher rpms
timing off? lost compression? some sensor that also simultaneously went bad during the jolt?
timing? the light links of the timing chain are matched up with the dimple on cam gear and crank gear, tried distributor one tooth advanced and retarded, but the original location runs best
lost compression? it looks like all my vacuum lines are in place. i did remove the a/c compressor and it's radiator while i was taking apart the front end, and i don't plan to put them back in
a sensor malfunctioning? o2? afm? tps? egr? could any of these cause the engine to stall at idle?
thanks in advance for any ideas ... my eyelids are heavy ... got to z zzz zz zz z zzz
Old 07-04-2009, 03:26 AM
thanks for the idea, would you still guess this knowing that the stalling started simultaneously with the exhaust leak? could the valve cover have shifted and began to loose compression?
Old 07-04-2009, 08:51 AM
i'm going to try spraying carb cleaner around the engine to see if there are any open areas on the intake side ... maybe the intake gasket is cracked like the exhaust was
Quick Reply: Drove over a ledge - Sudden, Extremely Loud, Engine Tapping (& timing parts question)
