driveway alignment write-up
#41
It sets the steering limit; the maximum you can turn the wheel. Around 32°.
The "caps" it refers to are also called "anti-groan" caps, which reduces noise when the suspension flexes with the steering turned to the stop.
#43
Im confused a little here, you said "#8 If it pulls to the oncoming lane, decrease the caster on the driver side, if it pulls to the passengers side, increase the drivers side caster."
Everything I have read shows a negative caster pulls. So if you are pulling to the left, and you decrease the caster on the driver side it would pull more to the left.
JookUpVandetti
09-30-2015 08:58 AM
