Doing 22RE HG - Have a EGR valve gasket question
Old 12-05-2007, 11:46 AM
jode's Avatar
Originally Posted by DeathCougar
All aftermarket kits are short gaskets. No matter how much their marketing department tells you its "complete" it never is. You will always need to get some gaskets from the dealer.
Just cuz it is common don't make it right (or acceptable) If it is, indeed, as common as you say it is, then cracksmkr.com has a unique opportunity to rise above the common purveyors of crap, include ALL necessary gaskets and excel in what they do. If they don't take advantage of this opportunity, they'll always be cracksmkrs in my book.
Old 12-05-2007, 02:19 PM
DaHos's Avatar
Well after 3 rebuilds I now know whats NOT in the engbldr kits, so I have a little "get from the dealer list" ready to go whenever I start a new project. I will continue to use his parts as guys like Ted are the kind you WANT to support.....
PS: Did you pick up new injector seats and o-rings when your were at the dealer too.....?????
Old 12-05-2007, 05:41 PM
langzaiguy's Avatar
What are injector seats? I sent away to have the injectors cleaned and they came with new O-rings and pentil caps.
Question @ the thermostat gasket--is there one? I know there's a big rubber O-ring where the thermostat sits, but is there a paper gasket as well? When I renovated the cooling system, I had the toughest time finding one--I had to cut one myself. Dealer told me there wasn't one. What say yall?
Old 12-05-2007, 06:25 PM
DaHos's Avatar
Just the thermostat o-ring, no gasket.....
Good call on the injectors, If not sending them out its a good call to get new upper o-rings and the lower seals where they mount into the fuel rail....ie: pentil caps (after 260,000 miles they tend to get a bit crispy)
Old 12-06-2007, 12:16 AM
  #25
skife's Avatar
And as an aside, not all 22RE's are the same. They changed several times from 85-95, including induction, exhaust, wiring, sensors, plugs, etc etc. Thats why when you swap out an engine from another vehicle, you have to reuse all your wiring etc.
x2 i've run into ALOT of differences swapping my EFI to an '84 motor.
there isn't a place to put the knock sensor, the timing chain is a different leingth, the valve guides are a little different, the head is compleatly different.
80-84 heads have hemi combustion chambers they also have domed pistons
lots of crap to deal with.
alternator bracket and alternator we're also different.
Old 12-06-2007, 01:13 AM
  #26
Matt16's Avatar
You could make a duct tape gasket.
Old 04-01-2011, 02:06 PM
  #27
SlightlyWhat's Avatar
Originally Posted by jode
I am just getting my head back on and everything put back together after a HG replacement on my 94 22RE. When I pulled the EGR, I seem to recall scraping a gasket off it, but now that I am going to reinstall everything, I don't have an EGR gasket in my engineblder.com engine gasket kit. This is what the EGR looks like to refresh your memory:
This is about the closest gasket I can find in the kit, but it doesn't really fit exactly right, and I'd REALLY hate to screw up this job. Any thoughts?
whoa whoa whoa...so wait where does that gasket go? I never took any pipes off...so do I still need it??? I don't want to bolt anything on right now I am getting ready to do the top end of the intake...and I have the same gasket but...the old one is still attached to the top intake manifold that connects with the egr...gizmo...
Old 04-01-2011, 08:14 PM
  #28
peow130's Avatar
Hey, quit your sniffling. You could have to punch out all the gaskets yourself.
Old 02-15-2012, 11:52 PM
  #29
giantjoebot's Avatar
I guess its a little late to be saying this, but the egr gasket is usually part of the intake manifold gasket. Look at the far left end of the intake gasket.
smthwsn357
05-01-2024 07:28 AM
bigjstang
08-25-2021 12:41 AM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
87blyota
07-10-2015 04:31 AM
Quick Reply: Doing 22RE HG - Have a EGR valve gasket question
