Does my 22re sound like its knocking?
Old 02-09-2009, 08:49 PM
toyota4x4907's Avatar
I have never heard an engine with a knock before, so obviously I don't know exactly what it sounds like. My '88 22re has been making a sound that seems to be a deeper tone than valve ticking (my '93 22re ticked a lot) and it is coming from the engine area, around #2 and #3 pistons, sort of towards the top it seems. I can't remember if the sound was present before or after I replaced my thermostat, but I had put a new thermo in, a 195*, hoping it would help make the air warmer inside. I did 2 trips of about 110 miles round trip, two days in a row right after I replaced it. Of course, the engine temperature rose significantly before the thermo would open, twice it reached the line just before the red zone. Also, on Friday night, I did some light snow wheeling with some friends. I almost got stuck on a hill (only because I was behind my friends F-150). I ended up revving it pretty high trying to get up the hill in 4-lo before backing down and trying a new approach. I made it up, but still revved it pretty high. ( no idea how high as I don't have a tach). Why I mention this? Well, perhaps overheating and over revving might cause a knock to develop. I'm just worried it is a knock. Heres a sound clip. Its not very great because the wind was blowing and messed up the sound a little.
http://s286.photobucket.com/albums/l...rrent=22re.flv
Old 02-10-2009, 01:17 AM
Matt16's Avatar
Try loosening the valve cover so that you're barely compressing the rubber grommets. It does sound a bit like its knocking doesn't it.
Old 02-10-2009, 02:14 AM
The nuts on the vc are pretty loose. Hell, when I first went to check the runner out, one of them had fallen off (luckily it got caught on some of the vacuum hoses) and ya it kinda does sound a little knocky...
It also has a leak between the exhaust manifold and down pipe..... but the "knocking" sound is more prevalent towards the engine than by listening through the wheel well...
Old 02-10-2009, 07:30 AM
desconhecido's Avatar
Can you tell for sure whether it's from the head or the block? Maybe listen with a stethoscope.
Old 02-10-2009, 10:10 AM
Dipstik_90's Avatar
That's a rod knock for sure. Mine sounded a little like that but only right after you would shift. Changed my rod bearings and all is good now, but from the sounds of things you need to pull the crank and have it machined.
Old 02-10-2009, 01:32 PM
iamsuperbleeder's Avatar
is it diesel?
jk...
yeah, hate to say it, but sounds like a rod to me
Old 02-10-2009, 01:35 PM
Yeah. Darnit this is bad. I just got another video/sound clip I'm about to post. I don't have the money or tools to do it right now
Old 02-10-2009, 01:37 PM
Yeah, I think this confirms it....
http://s286.photobucket.com/albums/l...nt=22re001.flv
well, if you've got the time, drop the oil pan and see if things have some play; you'd more than likely be able to wiggle the connecting rod on the crank it's it's gotten to the point of an audible knock. first though, drain some of the oil through a coffe strainer and see if you can get some metal shavings in it... tell-tale sign of main bearing wear...
Old 02-10-2009, 01:42 PM
91Toyota's Avatar
Got a suggestion;
Before you start tearing it down, could that possibly be the exhaust? Yes, the exhaust. Mine sounded pretty darn close to that (don't get your hopes up though!) when my egr line on the back of the head was NOT connected to the intake.
Good luck, I hope you get it all figured out!
Old 02-10-2009, 01:43 PM
or the knowledge....nor do I think I could steal my friend's garage for a few weeks.......
If I had the money and tools, knowledge can always be gained
Old 02-10-2009, 02:10 PM
Hm...So almost overheating could cause this or not?
It has 5w-30 synthetic oil in it, not leaking at all.
Maybe something is clogging some oil port or whatever and starved one or more of the rod bearings from oil?
Old 02-10-2009, 02:33 PM
ohyeahcrx's Avatar
Ratts...I was hoping mine wasnt the same sound..but it kind of is..Ive heard of rod knock being loud, and distinct but idk it mine sounds like that. Either way mine needs to be fixed (along with alot of other things :/) So good luck with figuring out exactly what it is..
Old 02-10-2009, 03:14 PM
Yeah I was hoping it wasn't either. It sucks.
Old 02-13-2009, 12:25 AM
Nevermind
Old 02-13-2009, 01:29 AM
7m4x4dude's Avatar
Nevermind
Old 02-13-2009, 01:34 AM
Haha I posted something...then changed my mind.
Old 02-13-2009, 03:49 AM
934rnr's Avatar
LoL I know your pain I just changed out my motor for kinda the same thing the #4 rod end was loose on my old motor..
It's because I had a leaking head gasket and things got hot. It makes bearings go really fast.
When you over heat best thing to do is shut it off right then and there. Don't continue to run it you end up ruining your bearings,
Mine sounded sorta like that only when I had the motor under load at certain rpms and it was also noisy too because the timing chain was worn as well as the guides.
Old 12-21-2012, 06:02 PM
Snortin Nortin's Avatar
I can't veiw the video but ya she got up there in heat it shouldn't heat past half way mark really!! plus u said your running 5w30 synthetic I would never go under 10w30 in these engines !! try 10w30 I run 15w40 with lucas it made oil press better and made it a little quieter! try it before u rebuild! plus the guys at toyota said that it won't blow up like that anyways!
montanatruck
02-26-2017 07:07 AM
coleypull15
11-03-2015 07:41 AM
PlayAwhile
07-20-2015 11:36 AM
keithporter83
07-18-2015 12:37 PM
Jeffreynmandy
07-18-2015 08:26 AM
Quick Reply: Does my 22re sound like its knocking?
