DIY headlight wiring harness upgrade for low $$
Old 01-13-2010, 05:56 PM
iamsuperbleeder's Avatar
Thumbs up DIY headlight wiring harness upgrade for low $$
I've seen this discussed a few times, but have still never seen a set-by-step write up, or even pictures of a full install
until now
don't hate me because it's a Jeep in the page the wiring is all the same, and this is REALLY good info, that I will be personally using here shortly when I install my new H4 conversion lights that I just got in
http://www.go.jeep-xj.info/HowtoHeadlightLoom.htm
Old 01-13-2010, 06:03 PM
xxxtreme22r's Avatar
Old 01-13-2010, 06:11 PM
myyota's Avatar
Thats a good write up, i saved it for future use. I just got a 160 AMP alternator for my 4Runner, so along with that and this head light mod it should be a nice improvement.
Old 01-14-2010, 06:06 AM
shaeff's Avatar
Daniel Stern:
http://www.danielsternlighting.com/t...ys/relays.html
By the way, make sure to use SEALED relays! And if you're using relay connectors like you should (not just crimp on female spade connectors)- use RTV to seal the back side of the connector. Then put dielectric grease in the connector for a 100% waterproof setup. I've never had a relay fail on me, even with one mounted in the back of the truck on the frame through northeast winters with lots of road salt.
Also, now would be a good time to upgrade your crappy stock headlight connector to a ceramic connector, and use 14awg wire. If you're tricky like me, you can add a simple diode in the wiring for dual beams. (dual beams = low beam stays on with highs, but high beams turn off with lows, a very easy modification. )
Old 01-14-2010, 03:22 PM
not that tricky, and I already have plans on doing so
diode from the high beam output at the relay to the low beam signal input at the relay
because also with doing this, I'm also going to run the relay signal input of my driving lights to the output of the low beams, so the driving lights will be on with both the low and high beams
Old 01-14-2010, 05:03 PM
peow130's Avatar
I'd do this if i knew my crappy schucks alternator wasnt going to give out at any time.
Old 01-15-2010, 09:57 PM
shaeff's Avatar
Right on. I say tricky, because any time I've mentioned it to anyone, they get all wide eyed and act like it's something new. Glad to see (no pun intended) that someone else is doing it! The extra light is fantastic!
Edit: I just read over that link you posted, - get relay harnesses. Don't use spade connectors on the relays. Do as I said above, and you'll NEVER have a problem. With spade connectors, you get corrosion quite easily.
Old 01-15-2010, 10:33 PM
betelnut's Avatar
Doesn't a diode mean a voltage drop? That means less voltage to the lamps, and need for a high-wattage resistor that can dissipate some heat. Try disconnecting your highs, and flip between high and low, see if the lows are a bit dimmer when the high beams are on.
There must be a way to rewire if you want the lows always on; just hook the lows up before the relay and leave the highs as they are. Or maybe I'm missing something....
Old 01-16-2010, 06:05 AM
a resister creates a voltage drop (actually just creates a resistance to the flow, which in turn causes a drop)
a diode allows power to only flow in one direction
Think about it like this. Wiring in a resister would be like taking a 3" exhaust, cutting it in half, and welding in a section of 1" pipe... all it's going to do is restrict the flow. But, wiring in a diode would be like putting a flapper-tip on the end of the exhaust. It's like a one-way valve, and is only going to let the flow go in one direction
Old 01-16-2010, 08:09 AM
shaeff's Avatar
What bleeder said, and the fact that you're NOT putting the diode in the path of that much current. You're making the low beam relay click the high beam relay on. Very low current.
If you were to put that diode directly from the high beam to the low, you'd burn it (and likely some of your wiring) up in a flash. They can carry high voltage, but not a lot of amperage.
Cliffnotes: you can only use the diode to trip the relays, NOT the actual lights. Let the relays take the current!
Old 01-16-2010, 08:50 AM
betelnut's Avatar
Shaeff, that makes a lot more sense. I'd like to see a diagram.
Super Bleeder, thanks for the description. Your analogy works well for describing diode forward voltage drop. The flap takes a small amount of force for the exhaust to push and hold open. The voltage drop is typically about 0.7V, which is about 6% in our 12V systems. Read more here:
http://www.kpsec.freeuk.com/components/diode.htm
This doesn't matter if the diode isn't going inline with the light bulb, for a relay it's no problem.
I don't know how the circuits are wired, but here's what I was thinking:
Attached Thumbnails DIY headlight wiring harness upgrade for low $$-lights.jpg
Old 01-16-2010, 01:38 PM
Schematics are fun to make
I picked up all of the supplies today minus the relays that I already had (cost about $40 for the supplies, but I ended up doubling that cost by getting a new soldering gun, and some other little things, lol), and will probably get started on the harness tomorrow, since the truck's broke down anyway due to the alternator going out
Soldering and heat shrinking all the connections too
Old 01-16-2010, 02:15 PM
Dammit Superbleeder you beat me to it, anyway mines nicer. lol. I hope this is right, someone please correct me if I am reading the tutorial wrong and let me know what I need to fix in the schematic. Anyway here we go. Basically the tutorial is using the factory headlight sockets to power the new relays which in turn operate the new sockets. I have added a dotted line with a diode which I believe is the right way to keep the low beams on with the high beams. Hope this helps someone.
Old 01-16-2010, 03:56 PM
that's basically the same setup, only I'm adding on a set of driving/fog lights that kick on with the headlights too
and I'm also installing some Hella 500FF's on the tube bumper on an independantly operated cuircut
Old 01-16-2010, 07:56 PM
JamesD's Avatar
Years ago I was going to make my own but after I priced the sealed high quality relays and after I seen how expensive they were at the time I just bought the kit. I bought it from Northwest Offroad. It is actually the Painless Wiring kit here: http://www.painlesswiring.com/webcat...=4x4%20OffRoad
I did not pay that price. I think it was roughly $60 but I cannot remember. High quality wire and relays were used. I believe they are either Hella relays or Bosch.
James
Old 01-16-2010, 08:08 PM
well I've already got a set of good 40amp relays that I got from work for free, so that was a discount for me there
plus, I've always enjoyed the puzzles of wiring
Old 01-16-2010, 08:32 PM
aviator's Avatar
Looks good guys but why use woosie 14AWG (only one size up from the 16AWG in stock sys.)? Step up to a more manly 12AWG or even 10AWG (if your chest is hairy enough ). Yes the wire will be heavier and may be a little stiffer but the resistance will be even lower and you'll be able to go to some seriously high lamp wattages with it.
Old 01-16-2010, 09:04 PM
shaeff's Avatar
Although you will see an improvement over the old wiring with 14awg, 12awg is a better choice. 10awg isn't enough of an improvement over 12 to warrant the extra cost and weight, IMO. Check out the Daniel Stern link I posted earlier in the thread.
And use heat shrink that oozes adhesive if you want it truly waterproof.
Old 01-16-2010, 11:16 PM
a4runnerfreak's Avatar
Location: Grew up in S.C.V, So Cal.....now in Hampstead, NC
'Bleederdude, please do your own write up, with pic for each stage, and write it up, say for some1 who doesn't know or really understand wire....like me! I've wanted to something very similar, but using Hella 550's....
Old 01-17-2010, 04:20 PM
too late freak
fabbed a relay mounting bracket out of a large hose clamp; worked like a charm
mounted the fuse block
ran the wires from the fuse block, and from the original headlight socket, with the diode in bewteen the two leads from the original plug
and found a suitable place to mount the realy assembly, right on the inner fender behind the battery
ran the new headlight plug wires, then dropped the battery in to make sure there was plenty of room still
threw some fuses in the fuse block
and everything works right!
although I don't have any other pics on the process... I was kinda in a hurry as I was loosing light...
and I realise I didn't use actual relay sockets wire in; I just used the spade connectors. I've used them just like this in the past wirh no problems; if I do get corrosion issues, I've got plenty of extra wire to cut the spades off and hard-wire in some sockets instead
Quick Reply: DIY headlight wiring harness upgrade for low $$
