Differences in Driveshafts
Old 08-25-2010, 03:01 PM
tumor21's Avatar
Differences in Driveshafts?
This might be a Newb question but...
I'm doing a 5spd swap into my '87 extra cab using a manual trans pulled from an '86 reg cab. Do I need a new drives shaft or can I reuse the one I have attached to the auto trans in my truck right now?
Old 08-25-2010, 03:04 PM
waskillywabbit's Avatar
Most pickups have a 2 piece dshaft, but I just used a 1 piece when I did my swap.
Old 08-25-2010, 03:06 PM
myyota's Avatar
Your going to need a new drive shaft, if i remember right the one you have will be a little bit to short.
Old 08-25-2010, 03:07 PM
Yep, I did have it lengthened now that you mention it, but I added duals at the same time too, so actually I might have cut it down. I did something to it but used a 1 piece.
Old 08-25-2010, 03:09 PM
xxxtreme22r's Avatar
should have all the info you need, maybe: http://www.4x4wire.com/toyota/faq/parts/
Old 08-25-2010, 03:14 PM
tumor21's Avatar
damn. If I can't get the one off the '86 reg cab donor truck, Should I be able to grab one from any 5spd truck (reg or x-ted cab) or 4runner?
Old 08-25-2010, 03:40 PM
greatskiiiier's Avatar
i would stick with a 2 piece design for the no-slip-yoke properties but thats all the advice i can give ya
Old 08-26-2010, 12:20 AM
Green93's Avatar
I'm about ready to do this swap on my 1993 pickup. Runners are everywhere here but there aren't any pickups to grab parts from. I believe there is only an inch or so difference in length of the transmissions. I think I'll just run it on the street like that while I order a driveshaft spacer from 4crawler. Maybe something you want to look into.
http://www.4crawler.com/4x4/ForSale/...ftSpacer.shtml
Jason
Old 08-26-2010, 04:39 AM
isn't the 1 piece driveshafts supposed to be better than the 2 piece cv style shafts? the reason I am asking, is I believe the P.O. of my truck swapped out to the single piece driveshaft and I have a spare one that is also the single piece.
Old 08-26-2010, 08:44 AM
tumor21's Avatar
Jason
Thnx Green. I never saw these things on 4crawler and I'm thinking these may be the way to go since I'm told my drive shaft is going to be too short. Very cool looking too...
Old 08-26-2010, 11:20 AM
well talking from my jeep days, the upgrade for jeeps is a slip yoke eliminator kit, meaning the driveshaft doesnt slip from the tcase but inside of itself like the stock yota ones do. this eliminates any chance of spitting a driveshaft due to too much axle droop
Old 08-26-2010, 11:30 AM
I am talking about the single driveshaft vs the two piece driveshaft with the double cardon joint on it. which is what I think of when someone says two piece driveshaft.
Old 08-26-2010, 11:52 AM
OHHH, ive only owned SWB yotas which have the single piece driveshaft, ive seen the two piece on bigger trucks but never on a yota, learn something new everyday
Old 08-26-2010, 11:59 AM
http://www.4x4wire.com/toyota/tech/driveshaft/
Old 08-26-2010, 12:55 PM
lol ya thats the site i read it on, i thought you meant the conventional driveshaft as apposed to the yota style that has the telescoping section in it
Old 08-26-2010, 12:57 PM
nah I'll save the crappy conventional driveshaft topics for the jeep fourms.
Old 08-26-2010, 10:31 PM
peow130's Avatar
Strange.
My long wheelbase toyota doesnt have a two piece driveshaft.
And my long wheelbase 81' didnt have a two piece, either.
Old 08-27-2010, 02:56 AM
I know, those two piece ones, don't seem to be be very popular, but they do exist.
mreagen
09-08-2015 03:46 PM
Peevedkitten
11
08-31-2015 06:57 PM
Lcb98toy
11
08-26-2015 05:28 PM
94yotaky
08-19-2015 11:15 PM
Tonetrk
08-06-2015 10:06 AM
Quick Reply: Differences in Driveshafts
