Denso spark plug wire set does not include coil to cap wire
Old 04-11-2013, 10:04 AM
qqq6677's Avatar
The Denso spark plug wire set for my 1992 pickup, or any model vehicle that I can tell, does not include the coil to distributor cap wire. Which brand wire should I replace my current coil to cap wire with? I've searched for a Denso cap to coil wire and have not found any. How much of a problem is mixing ignition parts brands? The OEM wires for my truck are Yazaki, and most of the rest of the ignition parts are Denso from what I understand. So mixing quality brands may not be a problem. Thanks for any replies.
Old 04-11-2013, 01:45 PM
Co_94_PU's Avatar
A "High tension cord" set should include all the wires. including the one you're missing.
What part number did you recieve and from whom did you source it?
Old 04-11-2013, 03:15 PM
highonpottery's Avatar
mine came with one... i'd call up the place you bought it from and ask for a new set
Old 04-11-2013, 07:14 PM
snobdds's Avatar
Every set I've ever bought has had the coil wire. It just be standard with any set...
If you don't find anything, next to denso or OEM (Yazaki), NGK makes a good wire set...
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
steve miller
10-10-2015 01:40 AM
bryan34w
07-06-2015 05:53 PM
toyota32
07-06-2015 05:42 PM
karbin
07-05-2015 11:37 PM
Quick Reply: Denso spark plug wire set does not include coil to cap wire
