Degreasing tips please?
Old 09-08-2011, 01:30 PM
BMcEL's Avatar
Originally Posted by Zack1983
Also, the biodegradable claim is nice, but it does not make the oil and grease that you are getting off any more "eco-friendly".
Words of wisdom.
Old 09-08-2011, 03:04 PM
blake.nemitz's Avatar
Originally Posted by vwfastg60
Purple power works great for me. I use it all the time. I hose it on let it sit a few hose it on again or scrub the thick stuff with a wire brush and spray again, Pressure washt the truck and the driveway.
i use that for cleaning my shower. spray it on and wash it down no elbow grease required ha ha
Old 09-08-2011, 04:08 PM
demoss32's Avatar
Spray lots of degreaser, cover your electrical components and intakes. After spraying try using a pressure washer.
_________________________
89' 4Runner- 22RE stock
Old 09-09-2011, 09:10 AM
dmwahl's Avatar
I've used Simple Green a lot, buy it by the gallon, and it's safe on aluminum. I would be careful with a pressure washer on any kind of seals or moving parts, it can force water past the seals and you know what happens then. Keep your distance with the pressure washer, or just use a garden hose or sprinkler.
Old 09-09-2011, 11:03 AM
  #25
andrewflores17's Avatar
Army uses simple green we got that stuff everywere works good to gota let it sit for 10 15 min for it to work the best though .
good idea about the bag and the air filter i always just avoided it as best as possible
think my engines ready for a good scrub down and my transmisson
Old 09-09-2011, 04:40 PM
  #26
peow130's Avatar
Super clean degreaser.
Not necessarily safe for the environment, but it'll take grease down to pound-town.
Old 09-09-2011, 06:30 PM
  #27
BMcEL's Avatar
Gasoline FTW!
Old 06-13-2021, 03:24 AM
  #28
aparna60's Avatar
RX Marine was established in 1996 in Mumbai, India; as chemical manufacturing company catering exclusively to the needs of the marine industry. In a short span of 12 years the company has established itself as one of the leading wholesale suppliers of a wide range of chemicals for - Marine industry internationally - and other local industires and plants. Our client list bears testimony to this. The RXSOL policy has its foundations on two pillars of strength - a continuous investment in research and development to deliver premium quality products and a commitment to service.
Degreaser
Old 06-13-2021, 12:16 PM
  #29
2ToyGuy's Avatar
When I was in the Corps, we used a chemical called TriChlor. Trichloro-triflouro-ethane. Worked fantastic. Nasty to the environment, but back then, as long as we disposed of it "properly", no problem. We used it in an ultrasonic tank, and a few minutes would clean ANYthing. Including rifles. Took the grease and carbon RIGHT off. It had a give away, though. It would turn the areas with the phosphate finish, the matt-black ones, a nice, bright, white. If you didn't reapply a layer of gun lube to it, the armory types would have a fit. But heck, the rifle was CLEAN!
When I got out, Simple Green came along after a few years. It works pretty well, not as fast, but nearly as effective. I use Simple Green for all kinds of cleaning. Counter tops, laundry, engine grease, you name it. Much more variety to it's capabilities than Trichlor had
I don't use it on my weapons, though.
Have fun, all!
Pat☺
JonG85
01-18-2023 04:31 PM
kawazx636
10-06-2021 03:03 PM
Zach_trun
01-22-2020 04:42 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Degreasing tips please?
