Damn it's 3.slo!
Old 05-20-2007, 12:25 PM
Schralper's Avatar
Damn it's 3.slo!
FINALLY got my fresh engine and new clutch installed.
1st rebuild I got had a leak inside the exhaust port.
Only to be found once I had the engine installed and ready to fire.
This engine is stock except cams 222 dur/ .400" lift
Suppose to be 190hp/210ftlbs but DAMN its SLO!
I even did the ISR mod. Cuz that's some lbs there!
Pulls good but I guess I'm use to V8's
Oh well glad I didn't bother w/ headers I can't see them helping THAT much
Might have to replace the stock muffler cuz it's a monster.
Old 05-20-2007, 12:46 PM
Bear80's Avatar
The 5vze motor is the 190hp motor, but the 3vze aka 3.slow is only 140hp. There is no way you can get a 50hp gain with just a cam. Sounds like your 3vze has the common power issue, does your motor run good until it warms and the computer hits closed loop mode?
Old 05-21-2007, 11:06 AM
Schralper's Avatar
TOYOTA 3VZE 3.0L V6 REMANUFACTURED HI-PRO / HEAVY DUTY ENGINE
190HP @ 4800 RPM / 210FTLBS @ 4800 RPM
THIS ENGINE HAS THE FOLLOWING:
# NEW HYPEREUTECTIC PISTONS.
# NEW ALUMINUM PERFORMANCE ROD & MAIN BEARINGS.
# NEW THRUST BEARINGS.
# NEW OIL PUMP.
# NEW FULL GASKET SET.
# NEW MOLY PISTON RINGS
# NEW BRASS FREEZE PLUGS
# NEW TIMING BELT
# NEW OVERSIZED VALVES, GUIDES & STEM SEALS.
# HIGH PERFORMANCE CAMSHAFTS 222 DURATION-.400 LIFT.
Well this is what the shop advertised for the engine I just put in.
The truck runs perfect, NOW
I knew these things were underpowered when I got it but just thought the replacement engine would help more. Probably need headers and cat back.
Oh well. I'm just gonna sell it and get something newer
Old 05-21-2007, 12:50 PM
GV27's Avatar
Yeah, if you're looking for a sportscar, an old Toy truck just ain't it!
edit: Aluminum bearings?
Old 05-21-2007, 01:07 PM
Jay351's Avatar
go dyno it!
Old 05-21-2007, 05:45 PM
Bumpin' Yota's Avatar
No.
The 3vze has 150hp @ 4800rpm and 180tq at 3800rpm. Cams will net about 15-20hp as is. Add 1mm oversized valves, PNP, and headers, and wham you will be over 190hp.... (Headers, 1mm oversized valves, and PNP has been dyno confirmed to gain 30rwhp putting the 3vze at the 180 mark without the help of cams.)
I have 259* duration camshafts in mine with 0.410" lift, the PNP, and 1mm oversized valves, waiting on headers still...
Old 05-21-2007, 05:50 PM
shoes138's Avatar
set them straight bumpin
Old 05-21-2007, 08:16 PM
mudbutt's Avatar
Originally Posted by Bumpin' Yota
No.
This has yet to be proven with dyno sheets only words. Bumpin, get your exhaust done, go dyno that beast, and I'll go get a dyno sheet to make you cry about any money you put into 3.slow
Most people belive that you get a intake 8-15hp + exhaust 20-25hp + cams 25-30hp + valves 30hp.....sweet I now have a 230hp 3.0! All theses mods working togeather will get you 30 hp. So you get a 180hp engine for the cost of more then a 3.4 swap.
3.0 are great stock, they move the vehicle and can last a long time. They are not built for high performance.
Old 05-21-2007, 10:36 PM
Bear80's Avatar
No.
Ah you're right but the first year 3vze did have somthing near 140hp, but the latter years had 150hp. After owning a good running '94 3vze I think when they are running tip top they are great, but would be really surprised if you can squeeze that much power out of it.
Old 05-22-2007, 07:20 AM
Schralper's Avatar
"3.0 are great stock, they move the vehicle and can last a long time. They are not built for high performance."
Ya know that's just what one of the parts guys said to me when I was getting new front shocks yesterday.
I actually thought I could trailer a snowmobile or 2 w/ it. That ain't happenin'!
Can't imagine driving one of these at hi altitude. It's slo enuff here @ 4200'
Old 05-22-2007, 08:23 AM
GV27's Avatar
Why the heck not? Mine pulls a camper at 10k feet no problem. 90mph of a 7% grade no, but it does pull it easy enough. A bit of rowing involved. Again though, I didn't buy the thing to get me anywhere in a hurry just get there. It'll maintain 65 or 70 up steep hills - that's all I need. I really don't need to be running 100mph up Floyd Hill.
Old 05-23-2007, 04:41 PM
Brad.'s Avatar
Nope don't need it to run 100mph up Floyd but it sure does make you feel slow when your maintaining the speed limit and everyone else is flying by at 100mph next to you!! My 3.0 auto pisses me off going up that hill man.
Old 05-23-2007, 10:42 PM
shoes138's Avatar
^^^^its all cuz of that overdrive in the autos!
Old 05-24-2007, 08:07 AM
GV27's Avatar
Ah yes - always forget about that. I have a stick and go up pretty good, singing "row, row, row your Toyota, roughly up the hill"!
Old 05-24-2007, 08:38 AM
fd59's Avatar
Get a 5spd with that 3.slo - you will be much happier.
Old 05-24-2007, 08:44 AM
8yota9's Avatar
i put my 3.0 throo a hell of alot it could trail 2 snowmobiels no prob in my eyes not fast but ittle do it. i hade 50 cinder blocks and 5 bags 80lb morter back there i took it slow really slow but it did it no prob and thats also with a bad rear. also hade a bathroom back there tile toilet wonder bored sink atleast like 6 7 hunderd pounds. i give that thing alota props i cn light em up too. with 33x12.50s on there. ive also hade it goin 110 till the rev limiter kicked in and stoped me. 3.0 aint so bad to mee
long live the yota
Old 05-24-2007, 09:59 AM
X-AWDriver's Avatar
I've driven a few 2nd gens and they make my 3.4 feel quick but in reality even the 3rd gen V6 is pretty slow on the takeoff. I ran 18.9@73mph at the Truckfest last year up here in Denver.
Old 05-25-2007, 09:26 AM
Schralper's Avatar
long live the yota
110 mph? Downhill w/ a tailwind!
Towing 600-700 lbs is like 1 sled and trailer. Then there's extra gas and gear.
2 sleds w/ trailer is like 1400-1500lbs.
I can chrip the 35" on my Burban what does that have to do w/ towing though?
Old 05-25-2007, 12:44 PM
TOYZILLA's Avatar
3.0 not a race motor
[QUOTE]
Oh well glad I didn't bother w/ headers I can't see them helping THAT much . ((((Headers will not only give you a little Hp but helps from blowing headgaskets))) I like my 3.0 it has alot more tork an power than the trusty 22re. It's no race car but does what it was made to do
Old 05-25-2007, 01:23 PM
GV27's Avatar
Maybe yours is down on power? I think my neighbor's camper I tow from time to time is like 1200lbs. When I took it over Berthoud Pass (11,300ft) I was still doing 50 or so at the top.
Heck, he pulls it with a Suzuki!
Not sure where mine'll top out but I've had it doing over 100 more than once. It runs 85 on my morning commute no problem. Not saying it's fast but you act like it'll barely move......that stuff about being unable to pull 1500lbs is just plain nonsense. People pull more than that with 4-bangers all the time.
Plus you read 8yota9's post wrong. He had 6 or 7 hundred pounds of stuff PLUS 5 80lb mortar bags (400lbs) PLUS 50 cinder blocks (sheesh - I dunno, another thousand??). That's a LOT more weight than a couple of sleds.
Quick Reply: Damn it's 3.slo!
