CVs spinning.. Dumb Question?
Old 06-15-2016, 07:48 PM
Rory Jackson's Avatar
Hey there everyone!
Here's the sich' :
1995 4Runner 3.0 V6 5 speed 4WD
When I bought it it had Aisin locking front hubs.
Recently did bearings, rotors, brakes, and balljoints both sides on the front. Apon reinstalling the hubs (yes the turn to free and lock just fine) and having the vehicle jacked in the front, still in 2WD mode : I spin one front tire and notice the cv is also spinnin, this happens both in lock and free. Is this normal? If it's in free shouldnt the wheels spin indepently of the CVs to avoid wear? Dumb Question I'm sure. But help would be appreciated!
Thanks in advance!
Old 06-15-2016, 07:56 PM
millball's Avatar
Must not be unlocking.
Does the wheel turn if you turn the half-shaft??
Old 06-15-2016, 08:14 PM
Half shaft ? That being the shafts coming from the sides of the front diff? Sorry, I'm new to working on driveline components
Old 06-15-2016, 09:27 PM
Turtl3's Avatar
Yes, half shaft/driveshaft/cv shaft/axle shaft. There may be enough reistance inside the hub that turning the wheel also causes the driveshaft to spin. Can u hold the shaft stationary while the wheel is spinning?
Old 06-15-2016, 11:19 PM
wyoming9's Avatar
The better question is will your axle turn with the wheel on the ground??
Old 06-16-2016, 02:41 AM
wallytoo's Avatar
^^ good idea.
also possible that the internal hub is not an IFS hub, but is instead an SA hub. if so, it won't disengage from the axle splines, even when in 2wd position.
Old 07-31-2016, 12:06 PM
Hey everyone sorry I've been away. Managed to fix it. turns out that I reassembled the locking hub incorrectly. Everything is all good now and working fine on that front! thanks
Agent Orange
08-05-2016 09:28 PM
mad_sb
07-02-2016 06:47 AM
fruitstripe
06-16-2016 05:18 AM
Trd95sr5
06-03-2016 07:52 PM
L4g63t
06-03-2016 08:53 AM
Quick Reply: CVs spinning.. Dumb Question?
