Crankshaft Pulley
Old 07-18-2009, 01:05 PM
langzaiguy's Avatar
Crankshaft Pulley
Well, I've hit a wall. I've gotten my center bolt out, and I've gotten the four smaller bolts out of the pulley. Now what? I can't seem to get the pulley loose! Any suggestions?
Old 07-18-2009, 02:26 PM
JJ'89's Avatar
Well, you need a proper puller. If you tap it off with a hammer, you will likely damage the damper and need a new one. Happened to me.
Old 07-18-2009, 03:46 PM
Team420's Avatar
I always use a rubber mallet, just dont wail on it, tap gently, and tap different spots ev time.
Old 07-18-2009, 05:38 PM
PlugItIn's Avatar
you can get it off with a hammer or a rubber mallet. Thats what I use atleast...just don't beat the crap out of it and remember to tap it around the whole circle
Old 07-18-2009, 05:48 PM
pb4ugotobed's Avatar
You can try spraying it good with PB and then using a brass hammer, give it a good whack in the center. Sometimes it will break it loose, and then you can work it off with your hands. You could also try taking a pair of large pry bars, one on either side of the pulley and by alternating prying with one bar or the other kind of 'walk' the pulley off there. Be careful with this though, I've seen people pry too hard and that pulley break loose and come flying off and nail the pry-er in the face. not pretty. Sometimes, no amount of beating on it will make a bit of difference, and you just need a puller to get it off. You can get a whole puller kit at harbour freight, northern tools, cummins tools, or wherever for about 10 bucks and makes life way easier. The puller is a hundred times easier than any amount of beating, prying, cussing, screaming, or tools flying across the shop at the wall.
Old 07-18-2009, 08:18 PM
dntsdad's Avatar
autozone or any national retail store like that will loan you a puller.
Old 07-18-2009, 08:58 PM
spanish-road's Avatar
harmonic pulley puller, or you can do it with a rubber mallet and do what they have been saying. It's not hard ya just gotta think about it.
Old 07-18-2009, 09:01 PM
ILLINOISYOTADAWG's Avatar
try going to autozone or like a farmsupply place rualking if in mid west or harborfreight and get a three jaw gear puller shouldn't be over 20.$ or get your bfh and spray it pb
lol
Old 07-18-2009, 09:46 PM
iamsuperbleeder's Avatar
huh... mine wriggled right off by hand, even after being locked in place for 296k miles
Old 07-19-2009, 07:09 PM
bugs1961's Avatar
They should come off by hand but some of the folks here have reported water pump leaks that caused the pulley to rust into place. You can rent a harmonic balancer puller from an auto parts store or buy one for less than $20 I would imagine. Makes the job quick and easy, without damage.
moparbay
10-06-2015 09:24 AM
Obmi
10-04-2015 11:30 AM
EVars
09-29-2015 02:06 PM
voiddweller
09-28-2015 11:21 PM
charlie_fong
09-27-2015 10:06 PM
Quick Reply: Crankshaft Pulley
