Crankcase Vent. questions
Old 02-24-2011, 10:59 AM
finneys98xj's Avatar
I have a question about my 3.0l. The vaccum hose coming from the valve cover(beside the oil cap) then hooking in to the intake hose. Has anyone put a filter on this line so the thottle body doesn't suck oil into the intake tube? I pulled the hose off the throttle body and it has a thick oil in the tube all the way down to the elbow. The elbow has some really thick sludge.
Anyone has any tips on how to fix/prevent this?
Old 02-24-2011, 11:19 AM
mt_goat's Avatar
Yep, its commonly called a "catch can". So try searching that, here's one writeup: http://www.gassavers.org/showthread.php?t=290
Mine on a 5VZFE:
Old 02-24-2011, 11:35 AM
Thank you that is EXACTLY what I'm looking for.
Old 02-24-2011, 11:41 AM
mt_goat's Avatar
Yeah I know BTW if you are getting a lot of oil in your can it is a sign of engine blow-by and you might start saving for a rebuild. My engine is low miles and I have never had to empty that catch can yet. It was a long time before it even had a trace of oil.
Old 02-24-2011, 12:39 PM
I just get engough to give the TB an oily coat. I'm going to clean it REALY good and just wanted to see if anyone had found a way to reduce or do away with any oil getting into the TB.
dumpster84
04-30-2016 06:03 AM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
4Runnin2000
07-29-2015 06:09 PM
Quick Reply: Crankcase Vent. questions
