Crank case vent
Old 06-26-2013, 07:10 PM
whitecollarredneck's Avatar
Crank case vent
I want to run my air filter/AFM up by my intake manifold but my crank case vent is in the way. I took the hose off to see if I could just put the filter on it and I saw a little oil around the fitting. If I relocate my vent and turn it sideways will it leak oil all over under my hood?
Old 06-26-2013, 10:26 PM
cman1's Avatar
yep,too much crankcase pressure. mine did the same thing.
Old 06-27-2013, 11:53 AM
Just from moving the vent?
Old 06-27-2013, 01:45 PM
cman1's Avatar
yep,put a filter on mine and blows oil on the valve cover.other people has said the same thing.
Old 06-27-2013, 02:56 PM
What if i relocate it but keep it upright?
Old 06-27-2013, 03:52 PM
cman1's Avatar
take it off,start the truck,and put your finger over the hole,and youll feel how much pressure builds up.
Old 06-27-2013, 06:55 PM
Punchy's Avatar
Alot of ring blow by, The PCV valve and that vent try to keep a negative pressure in the crankcase.
Old 06-27-2013, 07:23 PM
cman1's Avatar
try is the key word.
calderp
Engine Swaps
08-16-2016 05:15 PM
justdifferentials
Just Differentials
09-17-2015 06:14 PM
TJWilly
07-31-2015 02:05 PM
calderp
07-27-2015 09:58 AM
britishdudes2dr
07-25-2015 06:47 AM
Quick Reply: Crank case vent
