Cost of going from R12 to R134?
I was wondering what the cost was to go R134 from R12 in your areas?
After A guy told me 8-1000 to do the job, I went and bought an A/C kit from ACKITS for 400 bucks, and will do it myself.
I replaced the compressor on my Tundra yesterday, and used the new tools to vacuum and charge the system.
After I do the 89 truck, the tools will be paid for with the savings.
i put the adapters on the lines on a 86 i had and put the r 134 in. a air conditioner man told me by the time the seals and other parts gave any trouble, it would most likely need work any way. i spoke to the man i sold the truck to and after 3 years it was still working good. i am not going to say it was right or not but that is my 2 cents.
i was under the impression that it was just the fittings that were different...
my '86 has already been converted though
pretty sure my '92 is R-134 too, right?
i need to learn as much as possible my truck didnt come with a/c.. and it sucks to drive it the hot summer days...
i got a few parts but i really havent looked into everything i need to set it up.
I'm converting to R134a while replacing a bad compressor on my truck. The dealer nearby quoted me $550 just for the R134a conversion.
Picked up a new compressor ($215), drier ($15), and expansion valve ($10) from ackits.com.
Green o-rings ($10) and 4 R134a service ports (2 hi / 2 low - $20)
I also bought some flush ($15) to purge the lines
ya, stacey david was talking it about either when he hosted trucks, or while he started hosted gearz
i think its called duracool
it is
go to this link for more info
http://www.duracool.com/
it is
Be very careful.
Hello, I think you should take into account that doing it yourself may be inexpensive, but if you do one thing wrong, or just leak all the Freon into the atmosphere and are reported, then that’s a $20k fine and prison time.
