Coolant loss 22re
Old 06-13-2009, 06:47 AM
GodwinAustin's Avatar
Coolant loss 22re
Well truck was running fine until headed out to eastern colorado and the heat and the poor 22re started to overheat - the temp gauge hadnt been working correctly and had been showing normal temps until it was too late and the engine was loosing power.
well checked the reservoir and it was full as well but the radiator when checked had only about 20% coolant in it
Well took it to my mechanic and he did a pressure test and checked for HG leak. Mechanic found no leaks in the system.
But I am loosing coolant, lots of coolant, about a gallon every four hours of driving or so. Nothing showing up on the ground. Oil is clean. rough idle.
Something to note is that the radiator is misbehaving - it has a brand new cap but still isnt drawing or returning coolant to the reservoir. Not sure if that could have something to do with it.
I say blown headgasket anyone else want to make my day and tell me it could be something else?
Old 06-14-2009, 04:54 AM
cchinny's Avatar
I agree with you. Blown HG. Surprizing you are losing that much coolant with none in the oil though. Is it leaking out the side of the head (i.e. not into the oil) and onto the engine?
Old 06-14-2009, 06:38 AM
No nothing on the engine. that's whats strange.
If it is the HG I was thinking of throwing a new motor in there since it had been running real real hot w/o coolant for awhile before I noticed - so I think there is a good chance the head is warped. Any ideas for a new motor?
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
itzmywife's
07-25-2015 04:55 PM
jjrbus
07-23-2015 05:05 PM
ryerye13
07-14-2015 08:27 AM
Quick Reply: Coolant loss 22re
