coolant level keeps dropping
Old 11-23-2010, 03:25 PM
yota864x4's Avatar
so i have a 1986 toyota with a 22r and the coolant level just keeps dropping. i will top it off and it slowly goes somewhere. theres no white smoke or anything so i dont think the headgasket is going. the engine was just rebuilt a couple thousand miles ago also.
and another thing is my heater doesnt get very hot. are these two related at all?? any help would be great. thankyou
Old 11-23-2010, 03:34 PM
4runnerx3's Avatar
Take each spark plug out and shoot some compressed air down each hole and see if any water splashes out.
Old 11-23-2010, 03:35 PM
Junkers88's Avatar
I've got the same issue, do you smell coolant every once in a while? My issue was/is that the dang over flow bottle has a crack in it and when the rad/fluid gets up to temp (after topping it off cold) it deposits the extra coolant into the bottle and it leaks out. Took me months to find this out.... now all I need to do is seal the damn bottle.
Old 11-23-2010, 03:40 PM
yota864x4's Avatar
ok, ill give that a shot tomorrow. thanks
Old 11-23-2010, 03:41 PM
yota864x4's Avatar
yea, every once in awhile i smell it. i have to clean out my overflow cuz it was full of mud?? i dont know how. sometimes i hear it boiling in the radiator also.
Old 11-23-2010, 03:58 PM
yotakeith's Avatar
u might possibly have a bad heater core. :/
Old 11-23-2010, 04:06 PM
SpecialScottie's Avatar
I had the same problem. Turned out to be a small leak at the top of the radiator that would evaporate before it got to the bottom
Old 11-23-2010, 04:07 PM
yota864x4's Avatar
thats what im afraid of haha those hard to fix/replace?
Old 11-23-2010, 04:09 PM
Junkers88's Avatar
Pull the over flow bottle and just wash it out, I think it's 2 bolts that holds it in there. You might have a crack or it might be coming out the top.
I don't know much about the lack of heat although mine is the same way.... You and I might be chasing the same issues.
Old 11-23-2010, 04:13 PM
yota864x4's Avatar
ill do that tomorrow also. well hopefully we can both figure out what the cause is lol
Old 11-23-2010, 04:25 PM
yotakeith's Avatar
um well ive never put a heater core in a yota. i havent been workin on mine that long. but i do know they usually take several hours.
Blamalam
03-12-2022 07:34 AM
SubiKing
08-21-2021 03:57 AM
Tacoma1313
08-17-2015 05:44 PM
Shagool22
08-14-2015 12:24 AM
JefferDean
07-31-2015 10:39 AM
Quick Reply: coolant level keeps dropping
