coolant leak behind thermostat?
Old 09-11-2011, 06:25 PM
sprockmember's Avatar
coolant leak behind timing belt cover?
I have a leak that appears to be coming from behind the huge "hardline" that comes out from the timing cover (connected by hose to radiator)... is this possible? I now know it's not the line that runs through the intake mani, and everything outside of the timing belt cover is dry... but behind it lies the problem.
Suggestions? I've checked the FSM and I can't tell if there is anything back there that would leak. Any advice or insight would be great. Thanks. -Nels
Old 09-12-2011, 05:15 AM
waskillywabbit's Avatar
Lots of little lines under there that could have sprung a leak. If you can't find it get it pressure tested.
:wabbit2:
Blamalam
03-12-2022 07:34 AM
SubiKing
08-21-2021 03:57 AM
the1998sr5
15
07-14-2020 08:35 PM
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
Quick Reply: coolant leak behind thermostat?
