Coolant Leak
Old 12-12-2007, 07:16 PM
langzaiguy's Avatar
Coolant Leak
Ahh the frustrations!!! I reassembled my truck after a head replacement. After the initial valve adjustment, the engine sounds great! The bad news is that there's a steady coolant leak coming from right under the intake. I'm thinking it's the pipe that connects right under the intake to the heater core. QUESTION: is there something more than an o-ring to seal the pipe, or is there a gasket needed? Could it be anything else under there? The thermostat housing seems to be secure.
Old 12-13-2007, 04:07 AM
Georgiadave's Avatar
I assume it is a 22re. It could be the heater tube, however, there is another hose/pipe assembly further up the engine under the intake, as I remember. I could go out and look at my 94 if you want.
Old 12-13-2007, 06:17 AM
FR_Javier's Avatar
iirc, there are coolant lines under the IM for the idle air control valve, the heater core, and a line that connects the water pump at the timing cover to the IM. i tried to reuse the old oring on the coolant line when i rebuilt my motor. it leaked lol. it was a pita trying to connect that line too. i ended up picking up a new oring at the parts store and modifying the line. i cut it and welded a #10 an fitting to it, then capped it. ill just run a flexible line to the heater core when i put heat back in.
Old 12-13-2007, 10:52 AM
langzaiguy's Avatar
Is the line that connects the heater core the only one that has to be disconnected to replace the HG? I take it that was the one you were having trouble with? That one is held in place by 2 10mm bolts, right?
Old 12-13-2007, 12:20 PM
sloth!'s Avatar
get a new oring and also use some silicone. I have also just used a lot of silicone a few times when I didnt have easy access to a parts store or oring assortment, but using a new oring is your best bet.
Old 12-13-2007, 01:25 PM
Aaronn's Avatar
I tapped mine with pipe thread after both bolts broke off in the intake...Then used a nipple with silicone hose.
Old 12-13-2007, 03:26 PM
FR_Javier's Avatar
im not sure if its the only one you have to remove. i took everything apart when i pulled the head. i removed EGR and the PAIR system completely, cleaned up some wiring and did some other stuff. but ya, its the one thats held by the 2 10s.
Blamalam
03-12-2022 07:34 AM
SubiKing
08-21-2021 03:57 AM
WellsR
12
07-31-2015 03:27 PM
itzmywife's
07-25-2015 04:55 PM
Avenged
07-09-2015 07:55 AM
Quick Reply: Coolant Leak
