Companion Flange Question
Old 05-09-2012, 03:43 PM
Outsane's Avatar
Over the weekend I swapped in a new to me third..
the Companion Flange was for a different year and the bolt holes were smaller and were not the same as my drive line, so I drilled it out. So now I am getting vibrations and I would like to eliminate this as a probably cause.
I didn't have a 30mm socket to take it off and swap at the time, one is being shipped now.
Can I swap in my old Companion flange with out needing to pull the third?
Like doing a pinion seal replacement?
Old 05-09-2012, 03:47 PM
slacker's Avatar
yep
it is a crush sleeve though , so be sure to put the nut back on exactly as you took it off .. count the turns , and stake it
Old 05-09-2012, 03:49 PM
Outsane's Avatar
thanks
for being a slacker you are quick
zombie_stomp
08-17-2015 05:29 PM
trailgoat
08-13-2015 05:54 PM
makemusic116
08-02-2015 05:23 PM
makemusic116
08-02-2015 04:40 AM
TJWilly
07-31-2015 02:05 PM
Quick Reply: Companion Flange Question
