Cold Air/Supra AFM Mount (dial-up beware)
Old 09-22-2010, 06:10 PM
  #41
thook's Avatar
Location: NW Ark on wooded ten acres...Ozarks at large!
Would that be a human elbow or a cat elbow? Cat elbows work GREAT!!! (bastards.....poop in my truck. <<<<snap!!>>> <<<<MREOW!!!>>>....tisk, tisk)
Old 09-22-2010, 06:20 PM
  #42
myyota's Avatar
That would be a silicone elbow. (i like cats by the way)
Old 09-22-2010, 06:28 PM
  #43
thook's Avatar
So do I, man. Relax.... I'm just horsing around. Ironically enough, I (and my wife) run a no-kill animal sanctuary on our ten acres. We have somewhere around 70 cats. No ones getting hurt, though. Just hollered at. I mean, they pooped in my truck....come on!
Old 09-22-2010, 08:27 PM
  #44
irab88's Avatar
Originally Posted by myyota
I have another idea for you to consider, maybe it will work. If you take the elbow shown in the picture and turn it so its pointing at the passenger fender, then get another elbow, either a 90 degree or 45 degree elbow, what ever one would work the best so the AFM and filter would point down towards the fender were the battery used to be.
hmmm... i like that idea...
more pics in the morning...
Old 09-23-2010, 05:27 AM
  #45
irab88's Avatar
it's morning. here's some pics
http://www.flickr.com/photos/ianrab/5017696688/
http://www.flickr.com/photos/ianrab/5017696694/
i think i could get my hoses to flex more if i removed the battery. i'm gonna try it this weekend and snap a few pics
Old 09-23-2010, 08:14 AM
  #46
thook's Avatar
Swanky!!
Old 09-23-2010, 10:59 AM
  #47
Jaino240's Avatar
I was wondering if the Supra AFM actually makes a difference? Would it be noticeable? Powerwise? Throttle response?
Old 09-23-2010, 11:09 AM
  #48
myyota's Avatar
It does make a difference, people have reported that there trucks have better throttle response and climb hills on the highway a lot better. The supra AFM allows the engine to breathe better, so yes it would be noticable.
Old 09-23-2010, 11:35 AM
  #49
A.Wilson013's Avatar
I would go out on a limb and say VERY noticeable. Granted, it's still not a 3.4 =(
Old 09-23-2010, 12:30 PM
  #50
irab88's Avatar
Originally Posted by c0ugar69
You would have to loosen the A/C hose and turn it down a bit, but you might loose some freon, might be able to do it without much loss. just loosen the big nut a little bit, just enough that you can twist the pipe, it has a o-ring in there so maybe it wont leak. then tun it down. thats how mine is.
pics later tonight, but, um, i have no nuts to loosen. it does look like i can meander some silly-con elbows through the hoses, though (wow, is it just me or did that sound perverted to anyone else?)
yes, yes, more, better. that about covers your questions, right
Old 09-23-2010, 08:27 PM
  #51
irab88's Avatar
here's the top of the compressor. notice the nutless hoses
http://www.flickr.com/photos/ianrab/5019688644/
Old 09-23-2010, 08:42 PM
  #52
myyota's Avatar
That`s the later style compressor, the hoses bolt right to the top of it so you can`t move them. Do you have enough room to make my other idea work, by going to the right and then down ?.
Old 09-23-2010, 08:51 PM
  #53
irab88's Avatar
it looks that way. i'll try it out (with newspaper tubes) this weekend. the hoses look like they have enough play, just the battery is in the way
you mean something that would go like this?
http://www.flickr.com/photos/ianrab/5019730148/
Old 09-23-2010, 09:01 PM
  #54
myyota's Avatar
Exactly, just like that.
Old 09-26-2010, 11:55 AM
  #55
irab88's Avatar
here is the link to my battery/intake swap thread. i thought it would be appropriate not to hijack my own thread
Old 02-22-2011, 03:47 PM
  #56
jakestolar's Avatar
OP,
Sorry to bring this thread back to life. I just picked up a supra AFM and as i went to bolt it to my factory air box I noticed it is a little taller than the factory AFM. Where did you get the bracket to mount an air filter to the front?
Thanks!
Old 02-22-2011, 04:32 PM
  #57
skoti89's Avatar
bump. thinking about doing this swap as well
Old 02-22-2011, 08:38 PM
  #58
irab88's Avatar
Originally Posted by jakestolar
OP,
Thanks!
you mean the rectangle plate with the 3" tube sticking out that bolts onto the afm? it came with it. if your's didn't come with it, i think autozone might have something that could possibly fit, maybe. or hit up your junkyard again and find one that will work.
oh, and if i have any recent activity, i'll most likely respond. no problem
great! however, if you plan on doing the battery/intake swap, don't do this. save your money and time. it cost me about $60-ish for the swap, and in retrospect, should not have done this. but it was a good first project, and if it's all you need, go for it!
Old 02-23-2011, 03:09 AM
  #59
jakestolar's Avatar
OP I appreciate the help! May the hunt for a rectangle plate begin!
Old 02-23-2011, 05:06 AM
  #60
shaeff's Avatar
If you're just looking to do the battery/intake swap, you can do that for about $10 in extended battery cables. That's the only thing I bought while doing mine.
Quick Reply: Cold Air/Supra AFM Mount (dial-up beware)
