Clutch fork floating??
Old 09-22-2012, 02:32 PM
mldave's Avatar
Seems like my clutch bracket is good and a fellow pulled a rubber boot underneath the truck and said the clutch fork is floating.Guess this would explain the non/or hard shifting?How long to pull the tranny on my 86 Toyota truck 4x4 2.4 and check and repair this?Could it be the clips on the fork and is there a spring there?
Old 09-22-2012, 07:35 PM
slow-mo's Avatar
Yes.
http://www.utoyot8.com/FullImage.asp...23%2c6%23..MTM
I'll let others chime in on the R&R of the transmission of a 4x4. I've done it on my 2WD.
Old 09-22-2012, 07:45 PM
old fart's Avatar
Dunno if this will help
https://www.yotatech.com/forums/f120.../#post51699217
And on my 88 4x4, the starter removal was the worst part for me, then the 2nd worst was the two bolts at the top of the trans. When i did mine, i just took out my drivelines, supported the transmission/transfer case, undid the lines, wire connectors, and bolts,(undid everything) then undid the bolts on the crossmember, and dropped transmission/t-case as one unit. A tranny jack is an awesome tool to have, or rent, lemme tell ya.
Old 09-25-2012, 06:22 AM
mldave's Avatar
My friend looked inside and saw metal particles and said it's likely from the throwout bearing,so I guess it's time for an Aisin clutch kit when money is available.
primordialbeast117
12-19-2015 12:23 PM
smilen724
13
11-08-2015 04:11 PM
the_supernerd
10-01-2015 09:20 PM
hiluxinargentina
09-30-2015 11:12 PM
hiluxinargentina
09-30-2015 05:51 PM
Quick Reply: Clutch fork floating??
