Climate control panel bulb s14w
I'm not having any luck locating a replacement bulb for the climate control panel in my 1987 SR5. Has s14w on the old bulb. Any suggestions?
YT Community Team
i got a LED bulb. I'll see if I can find the info
I don’t know if the Climate panel is the same as a 91 but this fit my truck, I tried the single LED that faces forward and it didn’t reflect through the plastic panel left and right and had a major hotspot, so I went with the 3 led one and used I little butyl to block the front facing bulb, on the plastic not the bulb(if that makes sense) it works great, very bright and even. But again this is on my 91……superbright bulb number is just type 74…..
The specs are on the site, I’m sure you can measure your old bulb and see if the dimensions will work.
https://www.superbrightleds.com/74-l...ure-wedge-base
The following users liked this post:
RAD4Runner (05-01-2024)
Dawsonmarch
02-26-2024 04:02 PM
GrimWolf
05-20-2019 07:03 PM
crappled
10-25-2005 10:29 AM
