check engine light after batt intake swap
Old 06-19-2013, 04:10 AM
KBar's Avatar
Exclamation check engine light after batt intake swap
I Finally swapped the battery and intake last night and changed to a cone filter. After I was done I started it up and the beast shut down about 20 seconds later, rechecked everything and tried again. This time I took it for a test drive and my results are check engine light, creeping, sputtering, and sounds like a slight backfire out of the afm.
The only thing I can think of since its so close to the intake now that i need to move the internals of the afm a tooth. But in all the write up about this swap it says nothing about a check engine light or havingto mess with the afm internals.
Old 06-19-2013, 04:39 AM
irab88's Avatar
i'm just gonna go down the list here:
-is this a 22r-e?
-is the afm pointing the right way?
-did you cut and splice any wiring?
-did you re-connect all the vacuum lines?
-did you move any of the spark plug wires?
-did you get the check-engine code?
Old 06-19-2013, 04:45 AM
KBar's Avatar
-is this a 22r-e?
1.yes
2.I'm pretty sure theres only one way
3.yes the 7 wires for the afm
4.never touched any
5.no
6.yesterday before doing this swap the truck was running perfect excep for minor coolant leak
Old 06-19-2013, 04:48 AM
KBar's Avatar
I've read your batt intake swap intake about 3 times before I decided to tackle this swap
Old 06-19-2013, 05:00 AM
irab88's Avatar
yeah, it's not too bad if you have all the stuff beforehand
all right, 2 things:
1) re-trace your splices, and make sure all the wires are correct. i've messed wiring up before, and it brings teh suck
2) do you have a check-engine light right now? if so, do this (p 170-172):
http://personal.utulsa.edu/~nathan-b...85diagnosi.pdf
using a paper-clip or short wire to short terminals 'TE1' and 'E1'
Old 06-19-2013, 05:14 AM
KBar's Avatar
Cool I'll try that at lunch, I never uderstood how to check for codes on my 4runner mostly because its never thrown a code lol
Old 06-19-2013, 09:14 AM
KBar's Avatar
its throwing code 27 which is sub o2 sensor, Any ideas?
Old 06-19-2013, 09:37 AM
irab88's Avatar
make sure the o2 sensor plug/s is/are clean. i had mine short out in a rain storm once.
also try pulling the efi fuse for a good minute or two, then plug it back in. sometimes that'll clear any codes that might have been tripped while moving wiring around
Old 06-19-2013, 09:48 AM
KBar's Avatar
But why would that code show up after the swap. It seems like its not getting enough air, and i think the sub o2 is for like california emmisions
Old 06-19-2013, 09:51 AM
irab88's Avatar
i live in maryland and have a california-emissions truck. just check to make sure, and definitely pull out the efi fuse for a bit
Old 06-19-2013, 09:53 AM
KBar's Avatar
I think im gonna start calling this truck murphy's law
Old 06-19-2013, 03:58 PM
KBar's Avatar
Yup 2 wires were wrong I ran out of one of the colors so they were the same color and after I triple checked them, kicked the hell out of the tire, threw the old air box across the yard. I walked back out to the truck 3 hrs later and was like "Damn these two wires are wrong".
side note- I noticed the little boost in power almost instantaneous.
rbravo1
06-29-2015 01:34 PM
Alex Bessinger
06-28-2015 10:05 AM
94hiluxZE
06-22-2015 10:42 AM
Mutinebullfrog
06-18-2015 01:36 PM
Dr. Evil
06-07-2002 09:19 AM
Quick Reply: check engine light after batt intake swap
