Cheapest Knock Sensor Fix. Code 52
Old 05-13-2017, 01:48 PM
maxscott1234's Avatar
ok code 52 back even after I got another sensor so well year with no light so good....
check wire had volt AC on ground so I removed replaced
is the knock sensor linked to throttle position sensor in any way ?
does the ECM know if voltage is to low for the throttle position
any one help
Old 05-13-2017, 01:49 PM
any luck
did you try the mod ?
raptor510
08-19-2015 02:15 PM
rjtrials
08-06-2015 07:25 PM
nonstop
07-24-2015 06:29 PM
smiley52
07-11-2015 05:16 AM
Quick Reply: Cheapest Knock Sensor Fix. Code 52
