Changing water pump on 86 2.4 truck??
Old 12-29-2012, 02:04 PM
mldave's Avatar
How long does it take to change the waterpump on a 86 Toyota truck 4x4 2.4 ?
Old 12-29-2012, 02:22 PM
Robert m's Avatar
hard to say for sure, but i did mine earlier this year start to finish in under 2 hours and i wasnt rushing it.
Old 12-30-2012, 02:29 AM
wyoming9's Avatar
Red face
Depends on your degree of skill.I know of some who it took a long weekend to get it done. others a hour.
If the bolts are rusted who knows.
one hint break the bolt on the power steering pump loose before you loosen the belt.
Then what else do you also plan to do ??
Coolant flush? New belts and hoses??
Old 12-30-2012, 03:39 PM
timothy47129's Avatar
Be sure to use locktite on the water pump fan to pulley studs and bolts too mine worked their way loose after about 500 miles and they were tight when installed.it took me about an hour to do mine but that was with a heated garage and air tools.
Old 12-30-2012, 03:48 PM
mldave's Avatar
Thanks for the replies..turns out the noise is a collapsed PCV hose.
Old 12-30-2012, 03:57 PM
It's always something stupid lol. A collapsed pcv hose does make an awful racket.i recently had a bearing go bad in my water pump start knocking like a rod knock. Talk about a sound that makes you sick to your stomach.
voiddweller
19
05-02-2016 09:10 PM
Ichneumon
09-27-2015 04:21 PM
noahstancik
07-10-2015 11:18 AM
93handmedown
06-19-2015 06:26 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: Changing water pump on 86 2.4 truck??
