CEL!....its not the O2 sensor
hmmm well i would have guessed that it was an o2 senser try removingthe ecu or maybe u could check ure injectors idle air control maybe a vacume line make shure u have no leaks in ure exaust
#25
oh, it also gets stuck on high idle when ever i go to neutral. I can punch it and it drops back down. I dont think it is physically sticking because when I put it in gear and let off the clutch just a little (w/o touching the accelerator) then put it back in neutral it goes back to a higher idle. Wait, I think that happened before the CEL came on... dunno, could be a symptom
Sam hain
19
09-30-2015 08:25 AM
charlie_fong
09-27-2015 10:06 PM
