CEL/3vze codes
CEL/3vze codes
CEL came on last night, so I pulled the codes this am...
22, water temp sensor....prety self exlanatory
24, intake air temp? didn't think there was an intake temp sensor?
31, manifold/airflow meter
Any ideas?
Any ideas?
Here's a link to the codes:
http://www.4crawler.com/4x4/CheapTri...es/index.shtml
My initial theory? Dead vane air flow meter. There IS an intake temp sensor, but it is part of the VAFM, not serviceable, and not replaceable. When you get the airbox off, you'll see a little black sensor at the 12:00 position on the outboard opening of the intake forward of the vane itself.
Ever get any resolution on this? I have the same codes 24 & 31. I know what they are and have an idea where to start looking, but it would be great to hear whether you got this resolved.
http://personal.utulsa.edu/~nathan-b...33volumeai.pdf
If you get both codes at the same time, I would suspect the wiring.
But run the diagnostics; then you'll know for sure.
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
