Catalytic converter stolen... California
Old 08-27-2012, 07:21 PM
foppert's Avatar
Hey guys i know its a topic that comes up a good amount, but i need a good replacement cat that will get my truck to pass smog here in Cali.
Also i was thinking about making the new Cat removable, and just using a straight pipe until smog time. I just figure the easiest way to prevent it getting stolen again is just to not have one. I'm not against them, i just don't want to lose the investment as it was stole in front of where i live, i cannot park anywhere else.
I don't much care about the environment, but i do care about my gas milage. Would a straight pipe change this?
I can see a sensor still on the exhaust system by where the cat was.... which i assume is the O2 sensor. So i think i am good there.
Any and all advice is welcome, I am looking for ideas on replacements, ways to prevent them from getting stolen etc... just no more jokes about lost cats in trees
Old 08-27-2012, 07:30 PM
matstaley's Avatar
Catastrophic converters are a waste of space. Straight pipe should help both power and mileage. How much I can't really say.
Old 08-27-2012, 07:41 PM
NickMiller's Avatar
He's in cali so he has to have a cat to pass SMOG...
Old 08-27-2012, 08:01 PM
SoCal's Avatar
Go to the scrap yard buy a cat. Then hollow it out and mount it up. It will pass smog just your nox will be right at the mark.
Old 08-27-2012, 08:22 PM
foppert's Avatar
You a 3.slow SoCal?, cuz it sounds tempting.
Old 08-27-2012, 08:38 PM
ksti's Avatar
Maybe you can clarify a little bit. I would think that's an automatic check engine light, which as you probably know is an automatic smog fail. Or maybe I'm missing something?
Old 08-27-2012, 08:54 PM
foppert's Avatar
Well i drove it today with no cat, just a big gap in the exhaust and there still is no check engine light.
Old 08-27-2012, 09:54 PM
vang_22re's Avatar
OBD1 wont throw a code. on the other hand, OBDll will throw a code. If you have a 3.0 then im asumming yours is a OBD1. I been driving with a test pipe for over 3 years. Gas milage stays the same at about 20mpg, but i have a 22re. I guessing it should be the same with your 3.0 Also have a cat on the side for smog. Haha i say go with the test pipe cause the after market cats now a day will not last till your next smog check. How do i know? I work at a smog shop
Old 08-27-2012, 10:58 PM
MaK92-4RnR's Avatar
i did the straight pipe / catalytic converter swap out. but all i have to say is dont get caught...
Old 08-28-2012, 04:03 AM
SoCal's Avatar
No problems No check Engine light. But I have a 22re
Old 08-28-2012, 08:12 AM
BMcEL's Avatar
It is illegal for scrap yards to sell used cats.
Old 08-28-2012, 08:53 PM
Keith B.'s Avatar
Originally Posted by vang_22re
... the after market cats now a day will not last till your next smog check.
This has been my recent experience on my 22RE.
Old 08-28-2012, 09:46 PM
BMcEL's Avatar
I've had a Magnaflow high-flow cat since 2008 and it's still doing its job.
Old 08-29-2012, 10:55 PM
abecedarian's Avatar
I just want to say to all: "thanks for the laffs."
Whatever the OP does HAS TO PASS THE FIRST TIME or it's all for naught.
The wrecking yard can't sell converters. The auto part store down the street can't sell converters. Converters can only be sold AND installed by LICENSED installers and the converters are serialized. Any "new" converter installed in Cali has to be certified for use on the vehicle it is being installed on.
Options- existing passes the tests... otherwise factory or CARB approved aftermarket only.
All this courtesy of the Democrats.
kawazx636
10-06-2021 03:03 PM
Longbed 90
10-19-2015 11:05 AM
Cycles
09-29-2015 06:37 AM
Scotttekoch
09-28-2015 10:30 PM
larrys93pickup
09-17-2015 07:05 PM
Quick Reply: Catalytic converter stolen... California
