cant set my ignition timing..plz help
Old 08-21-2012, 03:40 PM
Rld747's Avatar
K i jumpered teminals te1 and e1 in the diagnostic box...my check engine light was flashing but my timing mark was jumping all over the place..it has a brand new harmonic balancer, timing sprockets chain ect. I did the 12 o-clock trick on tdc wen i stabbed in the distributer and my truck fired up perfect..it runs decent...just has a really high idle...almost 2k rpm. Ive retarded the dist. Asmuch as the adjusting nut will let me and even closed down the air flow screw on the throttle body and it still idles at around 1500 rpm...revs ok..its a little slow on the acceleration but doesnt cut out of fall on its face...not acting like a miss and deffinatly not a dead hole...so what could it be? It has new cap and rotor...i checked all plug wires and they checked out fine...im stumped
Old 08-21-2012, 04:12 PM
MudHippy's Avatar
You don't have a problem setting the ignition timing...just yet. What you have is an idle speed problem. As in, it's WAY to high. No way in hell you're going to be able to set the ignition timing with it out of spec like that.
See the FSM 22R-E engine mechanical troubleshooting section. Where you'll find the 12 suspect areas that need inspected if a high engine idle speed condition exists.
http://personal.utulsa.edu/~nathan-b.../3troubles.pdf
Here's the reast of the FSM to use as your inspection guide for those suspect areas.
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Get to work!
Side-note: You might want to start with the most obvious cause. In fact it's so obvious the FSM doesn't even bother mentioning it. What's that you say? The idle speed adjusting screw o-ring. Unscrew it all the way out, and replace the o-ring on it. See if that helps. If not, then start going down the list of 12(starting with 1, then 2, and so on).
Sleaker
08-26-2020 06:03 AM
87blyota
08-23-2015 03:57 AM
80Truck
07-24-2015 03:12 PM
94whiterunner
07-12-2015 07:15 PM
cars-guy
07-11-2015 07:51 PM
Quick Reply: cant set my ignition timing..plz help
