Can not get spare tire down...and I need to! Any suggestions?
Old 07-04-2009, 11:45 PM
abecedarian's Avatar
Old 07-04-2009, 11:49 PM
annoyingrob's Avatar
Buy a plasma cutter. Takes all of about 10 seconds to remove the spare tire
I never cease to find uses for cutting things with mine.
Old 07-05-2009, 12:45 AM
dutchboy's Avatar
Hahahaha....yeah,now you gotta find some other space absorning spot to store your spare. Unless you got her hung on the gate. I,unfortunatly don't have the luxury of hanging mine on the gate. I was deteremined to get mine down and fixed so iIcan continue...keeping my spare outta valuable cargo space. Which I did,with some patience,"abe's" help and some spary snot.
Old 07-05-2009, 12:28 PM
the problem with my spare tire winch, is it spins freely, but the chain doesn't move at all. Something's terribly wrong with it. I just keep the spare tire in my bed for now..
Old 07-05-2009, 02:32 PM
  #25
dutchboy's Avatar
In that situation,I don't blame ya. Can ya get the three mounting bolts from the winch out,so you can remove/inspect the winch?
Old 07-05-2009, 03:09 PM
  #26
Robert m's Avatar
sounds like i need to start buying all the chain drive spare carriers i find out here in the local junk yards and selling them to you poor folks that live where water actually falls from the sky.
Old 07-05-2009, 03:13 PM
  #27
It's not a problem of water falling from the sky but frozen water falling and various salts applied to the road to melt the frozen water which get sprayed onto the bottom of the vehicle and cause corrosion.
Being from Victorville, you should know that.
Old 07-05-2009, 03:32 PM
  #28
dutchboy's Avatar
I'm on a small mission and a slow road to fabbing some type of weather prrof enclosed housing for the winch. Not sure if it's possibe,but Im gonna sketch it out and slowly work at it before this winter sets in.
Old 07-05-2009, 03:53 PM
  #29
reman it out of nylon and plastic- nothing to corrode or rust.
Old 07-05-2009, 03:59 PM
  #30
dutchboy's Avatar
Oooh...nice idea! Thanx!
Old 07-05-2009, 06:12 PM
  #31
Gizler00's Avatar
Originally Posted by dutchboy
You unbolted it from the crossmember?
How'd the h*ll did you do that if the spare tire was still up in their?
Well, I needed to get it down because I needed a spare and I started to unbolt all three bolts and then ended up snapping everysingle one. And right before the last bolt, I moved everything out of the way, including my legs adn feet, and let it drop to the ground.
Old 07-06-2009, 05:32 AM
  #32
Robert m's Avatar
why would i know that? victorville is in the mojave desert. we dont get much snow or ice that requires road salts.
Old 07-06-2009, 05:56 AM
  #33
My point exactly.
Old 07-06-2009, 06:07 PM
  #34
Robert m's Avatar
My point exactly.
oh sarcasm.... now i get it
Old 09-06-2022, 12:22 PM
  #35
Kevlarster's Avatar
N@, I'm up in Butler Co. I'm thinking I need a 1/2" dia pry bar to get in there and put a pipe wrench on that.
Old 09-06-2022, 02:38 PM
  #36
JoeS's Avatar
Yes. You use the long extension rod with the circular end slides into the winch shaft slot. The square end fits into a handle in the jack kit.
Old 09-07-2022, 11:55 AM
  #37
2ToyGuy's Avatar
Use lots and lots of penetrating oil on the mechanism. PB Blaster is a very good, and popular, oil. WD-40, and so forth are others. Whatever you prefer. WD-40 with white Lithium grease is actually very good. It penetrates well, and the white Lithium lubes great.
Whatever you prefer to use, use lots of it, let it sit for a day, use lots more, let it sit for a day, try to break it loose, use more, let it sit, try to break it loose, etc. Keep at it. It'll come loose eventually.
Chemical warfare at it's best
Pat☺
Peterbuilt84
12-24-2009 07:29 PM
LiveAdventure
12-29-2006 12:32 PM
Fink
12-11-2005 09:59 PM
Ilovemountains
06-17-2004 06:00 PM
JGage
08-21-2003 07:26 PM
Quick Reply: Can not get spare tire down...and I need to! Any suggestions?
