Can I swap an A340F for my A340H?
Old 10-30-2008, 02:19 PM
TehDago's Avatar
I have a 95 SR5 4x4 3vze with the A340H. My transmission case developed a crack and is leaking badly. I found an A340F from a Tacoma locally, and was wondering if it would work for me?
From what I can find the difference is the transfer case. If this is the only difference can I just swap the transfer case from my existing tranny to the new one?
Thanks in advance!
Old 10-30-2008, 02:49 PM
Dan.3's Avatar
negative the only difference isnt the transfer
Old 10-30-2008, 03:28 PM
TehDago's Avatar
Could you please elaborate?
Is it possible to use by changing to the taco TCase shifter?
Old 10-30-2008, 03:43 PM
swaycleveland's Avatar
aw4 trans will swap with a lil wiring and then you can use a 300 atlas transfer clock it and be gear driven an has lower gear to help the 3.0 make the wheels spin!
im seriously think about this option myself!
aw4 com in jeeps
Old 10-30-2008, 05:45 PM
TehDago's Avatar
aw4 com in jeeps
That sounds like a good option. Might be a little easier to find also. I will do some searches on that swap. Thanks for the idea.
Old 10-30-2008, 06:34 PM
TehDago's Avatar
If anyone anywhere near Las Vegas NV has a A340H sitting around let me know. Because I could use one right about now.
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
exporunner
3.4 Swaps
08-03-2015 06:10 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
Gevo
07-29-2015 11:15 AM
GeoRoss
07-24-2015 03:03 PM
Quick Reply: Can I swap an A340F for my A340H?
