Can Coolant go bad in storage?
Old 07-09-2011, 04:35 PM
Keith B.'s Avatar
I've got Toyota red coolant, which I pre-diluted with distilled water. It's been sitting in a sealed container for about three years. Can/does the stored, diluted coolant go bad or degenerate somehow?
Old 07-09-2011, 04:52 PM
peow130's Avatar
Does it smell like fish?
Old 07-09-2011, 05:37 PM
stackedyoda's Avatar
I know oil has a shelf life of 7 years, so I wouldn't think 3 years would be bad for coolant.
Old 07-09-2011, 05:54 PM
sb5walker's Avatar
It's possible the corrosion protection chemicals might break down some in 3 years. I would test the pH. Mixed 50/50 with distilled water, Toyota Red should have a pH of 7.3 when measured with these papers:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=110701564252
And test the specific gravity with one of these:
The freeze point of a 50/50 mix should be -34 F, but since antifreeze is not all ethylene glycol but contains about 3% corrosion inhibitors, the freeze point may be closer to -30 but shouldn't be much above.
If the pH and freeze point test okay, it's probably okay to use. But I would check the pH every six months or so, and replace when it gets to 7.0. You might consider using it for just a year or year and a half, instead of the full 2 years.
Old 07-10-2011, 03:10 PM
Keith B.'s Avatar
Thanks for the replies; I'll probably mix fresh to get the longest service life. Flushing coolant is a furtive, secretive clandestine activity here at the apartment complex--someything to be done as seldom as possible.
SubiKing
08-21-2021 03:57 AM
the1998sr5
15
07-14-2020 08:35 PM
itzmywife's
07-25-2015 04:55 PM
jjrbus
07-23-2015 05:05 PM
Poncho0206
07-10-2015 06:21 PM
Quick Reply: Can Coolant go bad in storage?
