Camry Alternator 3VZ Swap
Old 11-10-2010, 04:41 AM
RBX
RBX's Avatar
Anyone have any links to this? I have searched, and some folks acknowledge that it can be done, but i can't find any links.
From 92-94 the Camry with the 3vz engine came with an80amp alternator, i hear this alternator will bolt in with a dampner mod(this is where i am confused).
I have no problem going to the pick'n pull to grab an alternator to give this a shot, just looking for some insight.
thanks
Old 11-10-2010, 07:26 AM
Outsane's Avatar
i thought the pulley was different?
Old 11-10-2010, 07:50 AM
RBX
RBX's Avatar
that's what i hear, so i would have to swap pulleys..no big deal. I have also read that the spindle needs to be bored on the pulley because the Camry alt spindle is larger, again not a big deal.
Mounting and hook up is what i am really after. and experiences of course. I may have to spend the $5-$15 at the pick'n pull to find out for myself, but I'd rather have someone with FHE.
Old 11-10-2010, 08:05 AM
mastacox's Avatar
Don't bother with the camry alternator, do the 100 amp MR2 alternator swap. It takes minimum modification, and you can find the alternators cheap. I did it on my old '92 4Runner when I went to an electric fan and auxillary lights, great mod.
http://www.off-road.com/trucks-4x4/t...ade-18551.html
Old 11-10-2010, 09:12 AM
RBX
RBX's Avatar
^^^ Thanks, I'll read up.
Old 11-10-2010, 09:29 AM
RBX
RBX's Avatar
MR2 100amp Alternator
Did you change the pulley? Or perhaps i mean, was the spindle different sizes. The write up link you provided was helpful, but it doesn't' address my questions.
Thanks
Old 11-10-2010, 10:35 AM
mastacox's Avatar
Thanks
The pulley doesn't need to be changed because it utilizes the same kind of belt already on your truck. You'll just need to get a slightly longer belt as directed in the write-up.
Old 11-10-2010, 10:58 AM
RBX
RBX's Avatar
^^^ awesome! thanks
I also found out Myyota did this same swap, trying to hunt the thread down now.
thanks again
theking11863
03-19-2016 09:36 PM
redneck17
10-29-2015 09:09 PM
RobotMoose
Diesel Swaps
08-02-2015 11:00 PM
80Truck
07-24-2015 03:12 PM
wilbertd
07-06-2015 07:39 AM
Quick Reply: Camry Alternator 3VZ Swap
