calling all toyota certified techs!! (long)
Old 02-10-2008, 09:06 AM
jtlinna3vze's Avatar
Originally Posted by Targetnut
Is there any chance that your coolant temperature is too low.
A stuck open thermostat will allow the coolant to warm up when sitting still or going slow, but if you go down the highway the coolant temp will drop and the auxillary air valve will open back up and cause the idle to be high.
also, check the throttle and cable for binding. when it is idling too fast, try to manually close the throttle.
coolent should be ok.. gauge on the dash is in range.. scan tool said it was up to temp but i dont remember the number our head mechanic said it was at.. but all the hoses are at equal temps.. the lower that goes to the T-stat. the upper.. and also heatercore lines..
i never thought to try and manually close the throttle when its acting up?? ill give it a shot next time it acts up..
thanks for the ideas..
Old 02-10-2008, 04:13 PM
just a 22re's Avatar
get some spray white lit grease and spray the tb cable down this is the same thing that happened to my old honda i had and my buddys honda just spray it up move the cable and spray again then under dash and spray spray spray
Old 02-10-2008, 08:35 PM
bry-an's Avatar
hmmm I seem to remember hearing about cleaning a spring in the MAF sensor ..... anyone remember that? it has to do with throttle position or something ... I'll try to find it
Old 02-10-2008, 08:40 PM
bry-an's Avatar
ok heres the link but its for 22re I dont know if it applies to what you are saying.... also I was wondering about what else you have drawing on your electrical system... amps???? sometimes my revs start dropping when I got all my going at once http://www.4x4wire.com/toyota/minutemods/afm/
Old 02-10-2008, 08:55 PM
  #25
toytech76's Avatar
Ive had several 3.0's do this and I have found the throttle more or less sticks open a bit. One culprit I have found is the little dashpot to the left of the tbody(as you are looking down the throat). There is a very small adj screw that contacts the dashpot when you let off the gas. I have been able to de-adjust this screw back sometimes quite a bit to fix this problem. I would be willing to bet your problem is in your throttle body and not any of your sensors or any vac leaks
Old 02-10-2008, 09:32 PM
  #26
well everyone. i was on here for a while and doing some searching with the word "idle" came across a few threads about bad EGR's.. so i took a lipton brisk iced tea can.. cut it up and made a gasket.. blocked off my EGR and it hasent been a problem all day.. im kinda pumped cuz i have no vibration at idle.. it seems to have more power and throttle response.. well see if it comes back but i think i may have this one licked..
Old 02-10-2008, 10:40 PM
  #27
shoes138's Avatar
Awesome!!!! i think i may have that same problem also.....
Old 02-11-2008, 12:43 AM
  #28
Dan_P's Avatar
i have the same problem with my '90 SR5 3vze and it is the throttle body as some one already mentioned the you need to check your clearence between the trottle and the dashpot adjuster sometimes it stick's the best thing to do is lube the throttle cable and check the adjustments with feeler gauges. well ive been doing alot of reading and it seems that alot of you guys are doing the egr mod i guess ill give it a try also
06-01-2021 01:51 PM
God's Bounty Hunter
07-08-2015 12:54 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: calling all toyota certified techs!! (long)
