A/C Idle Relay?
Old 06-26-2006, 08:15 AM
momo76's Avatar
Question A/C Idle Relay?
Has anyone ever had to replace this thing before? I came across the part on ebay yesterday and bought because it said that if it failed it would cause you rpms to drop whenever your a/c compressor came on. My truck drives lousy when the a/c is on. It feels like the compressor is putting a strain on the engine. Any advice? I bought the part just in case.
Old 06-26-2006, 08:30 AM
TNRabbit's Avatar
Check this link: https://www.yotatech.com/attachment....achmentid=9115
This is the screw/bolt for adjusting the A/C compressor idle up and should solve your problem.
Ensure the engine is up to operating temp, turn the A/C on max, adjust idle up for @ 1100 rpm when compressor is on. Normal idle should remain @ 800 rpm (+/- 50 rpm).
mussy01
12-13-2016 08:20 PM
ghostmoney
08-06-2015 08:40 AM
stock87yota
07-31-2015 10:08 AM
jackiebrownia
07-20-2015 09:02 AM
bryan34w
07-06-2015 05:53 PM
Quick Reply: A/C Idle Relay?
