A/C Compressor wire cut! help! '89 pickup 3.0
Old 03-16-2012, 09:29 PM
azcheese's Avatar
I'm in the process of getting the A/C on my new to me 89 pickup, to work for the hot AZ summer i have ahead of me. After replacing a fuse and a belt i found that the positive wire from the compressor has been cut right next to the connector and I have searched and searched and i cant figure out where the other end is. My hope here is that someone can post a pic or a great description of where that wire would come out of the (and what) harness.
Seriously? I thought $3k was a good deal.
Old 03-17-2012, 06:05 AM
svdude's Avatar
Download the factory service manual and look up the wiring diagrams. I believe that wire is supposed to go to the AC amplifier.
Old 03-17-2012, 06:39 AM
Astralplane's Avatar
Here is where it goes on a 1994.
The wire goes inside the bottom of big wire loom
Old 03-17-2012, 08:51 AM
worshipmentor's Avatar
on my 87 22RE it comes out of that harness you have right below your hand that runs from the pass inner fender to the engine. as I recall there is little slack and it goes into the harness a lot further up than you'd think.
Old 03-19-2012, 08:39 PM
azcheese's Avatar
i fished around in the wire bundle above it and found the end. Thanks!
OffroadRalph
07-02-2015 07:28 PM
Yota.Jay
07-02-2015 12:57 PM
rwh2toyota
13
06-27-2015 05:39 PM
nyk08trx
06-18-2015 09:01 PM
Bajawfo
06-16-2015 07:31 PM
Quick Reply: A/C Compressor wire cut! help! '89 pickup 3.0
