A/C compressor removal
Old 07-20-2010, 05:10 PM
gsdog2's Avatar
Ok, trying to replace the A/C compressor on a 93' 4runner; I guess there is absolutely no way it comes out the bottom??? I'm trying to remove the P/S pump, but the pulley nut wont budge. Are there any suggestions how to remove the P/S pump PULLEY so I can remove the pump. Looks like the bolt behind the pulley wont come out far enough to remove the pump without hitting the pulley. Any help is appreciated.
Old 07-21-2010, 05:21 AM
InternetRoadkill's Avatar
The pulley is part of the clutch assembly, which is not all that easy to remove even with the compressor off the truck.
Old 07-21-2010, 05:52 AM
waskillywabbit's Avatar
www.ncttora.com/fsm
Old 07-21-2010, 06:13 AM
Marc's Avatar
You don't say what engine you have but on my 3.0 I moved the PS pump over and removed the compressor from the bottom.
It wasn't any fun.
Old 07-24-2010, 07:25 AM
gsdog2's Avatar
OK..that was not fun at all....no wonder we were quoted $1,000 for this job! Removed the P/S pump and pulled the compressor out the top; had to pull and re-install the clutch while it was still in the rig. Off to get it recharged. Thanks all.
mussy01
12-13-2016 08:20 PM
stock87yota
07-31-2015 10:08 AM
skoti89
07-08-2015 12:05 AM
bryan34w
07-06-2015 05:53 PM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: A/C compressor removal
