Burning Coolant HELP!
Old 09-21-2010, 06:00 PM
xtultegra's Avatar
Am I missing something?
OK! I found a leak in the timing chain cover and replaced that, put it all together and still got white smoke. I replaced the head gasket and still got white smoke. I just replaced the head and still I get white smoke but only after it warms up and I rev the engine. I suspect the cheesy no brand head gasket that came with the new head, but thought I'd ask if I am maybe missing another possible problem that someone else might no about!
Everyone says the possibility of a cracked block is very small!
Other than that, it sounds and runs great!
1990 Toyota PU 22RE engine.
Old 09-21-2010, 06:20 PM
Staff
DeathCougar's Avatar
Did you make sure to clean out your intake, airbox, and all vacuum lines which can/likely are coated with coolant/filled with water?
Old 09-21-2010, 09:22 PM
sb5walker's Avatar
The cold idle-up valve (called the "auxiliary air valve" or AAV in the fsm) in the throttle body is a thermostat-like valve that is controlled by coolant - if the o-rings are shot it can leak coolant directly into the throttle body.
http://personal.utulsa.edu/~nathan-b...34throttle.pdf
http://personal.utulsa.edu/~nathan-b...35auxiliar.pdf
(There apparently are o-rings in the plunger part of the valve that are accessed from a cover plate on the left of this photo of the 22RE t-body. Thanks to hilandfrog for this photo)
Or, I suppose it could be that "cheesy no-brand head gasket."
Old 09-25-2010, 11:51 AM
xtultegra's Avatar
No coolant or residue in airbox. I did clean the intake out.
I'll check those O-rings in the AAV (didn't know about those).
I think maybe my block is out of tolerance. .006 in center.
Old 10-06-2010, 06:09 PM
xtultegra's Avatar
Block was out of tolerance! Milled it: Problem solved!
Thanks all.
puddlepirate
07-30-2016 06:29 PM
alexcarey
10-14-2015 06:05 PM
dzldust
7
10-06-2015 05:39 AM
tylermx71
09-29-2015 08:49 PM
rmill05
09-27-2015 01:43 PM
Quick Reply: Burning Coolant HELP!
