broken tab on e-brake handle... replacable?
Old 01-03-2008, 08:03 PM
ozziesironmanoffroad's Avatar
Ok, so today as I am leaving the house for work, i let off the e-brake, and i hear a slight CRUNCH. didnt think much of it until i noticed the brake light was still on. so i pulled over, checked the brake and clutch fluid, fine. so i was messing with the handle, seems to be workin ok. so i jsut said screw it sicne i was running late. i talked to my mechanic about it, and he said i wanted to check for a little white 'nipple' on the bottom of the handle. so i did, and low and behold, theres a little bar on the handle that i guess compresses the 'nipple' to turn off the light. i pushed in on it, and it went off. turns out that bar broke. now my question is this: am i gonna need to buy a whole new e-brake assembly and install it for that, or can i just salvage the piece? my mechanic says its a one piece thing, but i dont know. ive tried supergluing it, but doesnt hold. i currently have the light disconnected from the e-brake handle so i dont have a red light glaring up at me. any help would be appreciated.
Old 01-03-2008, 08:05 PM
notanymore's Avatar
try looking at the stealership or a junkyard for one.
Old 01-03-2008, 08:13 PM
Staff
DeathCougar's Avatar
Its just a switch. Its removable (very very easy) and replaceable. Talk to your local dealer, im sure they can get it.
Btw i wouldn't suggest a local parts house, they will likely get you the brake light switch under the brake pedal. And thats not the one you need.
Old 01-04-2008, 04:00 AM
Yoda's Avatar
You are talking about the metal peg that pushes onto the switch?
It is a press fit into the shaft of the handle. I have changed it before. We had a parts truck, use a punch to tap one out, tap the replacement back in.
FWIW, the new part # is 46114-20010 Pin, parking brake plunger.
Old 01-04-2008, 04:37 AM
not the plunger itself, the tab that presses the plunger, but thanks every1
Old 01-04-2008, 06:39 AM
Staff
oopsie, i see what you mean now. I have never heard of one breaking!
Old 01-04-2008, 06:44 AM
MMA_Alex's Avatar
do a search for my e-brake thread! I broke mine, and was told that you can tap the handle hole, and put in a bolt that'll hit the light switch...or you can just ducktape the swtch so the light doesen't come on.
Old 01-07-2008, 03:57 AM
GSGALLANT's Avatar
Here are the details to finish off MMA Alex's post above.
My parking brake switch pin was broken when I bought my '93 4Runner. I punched out the broken pin from the parking brake handle shaft (this is easy to do with a hammer and punch when it is removed from the truck), tapped the hole to M6 x 1 (the hole size is perfect to do this), and installed a M6 x 1 (x 30mm, I think) bolt with blue loctite (after the handle is re-installed in the vehicle). It has worked perfectly since I did it 7 months ago.
the1998sr5
15
07-14-2020 08:35 PM
rushw
07-18-2015 01:46 PM
88yodabasket
07-13-2015 01:32 PM
jon.r
07-11-2015 03:34 PM
akaphilly
07-09-2015 02:34 PM
Quick Reply: broken tab on e-brake handle... replacable?
