Broke shock hoop , help me put it back together better.
Old 12-15-2013, 05:39 PM
v_man's Avatar
hmm...I bought the axle with the lower mounts already attached ... You may have just given me a new project ! Might be a B#*@ch to cut 'em off...
Old 12-15-2013, 08:20 PM
scuba's Avatar
You should still have more bracing on the shock hoop.
Some 1.25"/ .120 wall tubing attached to the hoop and braced to the top of the frame would suit you well.
Theres a reason why that stuff is included with shock hoop kits.
https://www.allprooffroad.com/pickupsuspension/55
Old 12-15-2013, 09:41 PM
v_man's Avatar
Correct scuba , I forgot to mention that I will be bracing soon , but I needed to get the shock on for daily ...
Any suggestions on how brace it best , Y shape , V ? Separate legs ...?
Old 01-02-2014, 03:58 PM
v_man's Avatar
Just wanted to wrap this thread up ...
I ended up reinforcing both sides of the front frame with this pre made , pre cut piece of 3/16"
from addicted offroad
http://www.addictedoffroad.com/index...roducts_id=288
I reinforced the hoop with some 1/8" tubing
Overall it was a lot of work to fix the broken mount , and I should have reinforced the hoop from the beginning , live and learn .
Old 01-27-2020, 01:27 PM
  #25
TXTRUGFLAT's Avatar
Thumbs up
this is a great thread. im about to do the same with my 84 Yota. broke the shock and tore into the frame on the passenger side. this gave alot of insight on what i need to do next. Thanks!!
anyone have recommendations on better shock hoops?
Old 01-27-2020, 02:03 PM
  #26
v_man's Avatar
Good luck on your fix! My repair from 7 years ago is still working well
The following users liked this post:
det107 (01-28-2020)
Jmiller1023
23
08-06-2015 07:03 PM
toyota32
07-06-2015 05:42 PM
Jnkml
07-06-2015 01:20 PM
newzingo
06-24-2015 01:50 PM
Quick Reply: Broke shock hoop , help me put it back together better.
