Brembo vs. Napa
All steel isn't the same, cheaper rotors won't have as a high quality steel, and sometimes are actually thinner than more expensive ones.
Also, with cheaper rotors you're more apt to get warped rotors out of the box.
Warped rotors will still work, but you get what you pay for.
If they're warped all the time [the second you touch your brakes you get vibration/shimmy] resurfacing them MAY get rid of the warping.
If they only warp when they're hot resurfacing is almost useless. Usually the vibration/shimmy comes back after the first heavy braking.
Better mid level braking.
If you have to brake hard on the hiway I doubt the stock brakes will lock up right away, but they do shimmy and fade.
Better brakes should lessen/remove that.
ashamsuddin
17
01-13-2023 03:17 AM
kcaudill
10-10-2015 02:39 PM
Scotttekoch
09-28-2015 10:30 PM
