Brake line fitting Thread size.
Old 11-28-2006, 02:40 PM
neoworm0's Avatar
Anyone know what thread and pitch the toyota brake line nuts are. 10mm x 1.0? I am trying to find an adapter and need to know. Thanks.
Old 11-28-2006, 02:44 PM
4Crawler's Avatar
Yep, M10x1.0 on the thread. I carry some male and female M10x1.0 to AN-3 adapters and have also made my own adapters out of brass tube fittings. Just re-thread one end of the fitting to M10x1.0 and get the other end in whatever size you need. Been running a set of those on my front brakes for about 7 years now.
Old 09-26-2010, 10:08 PM
viaduct09's Avatar
Old post
Do you have any pics of your 10X1 to ANS retrofit?
Old 09-26-2010, 10:34 PM
4Crawler's Avatar
Here is a male and female M10x1 fitting, both with AN caps:
Old 09-27-2010, 04:42 AM
skypilot's Avatar
Yep, old I know.
I just did my clutch this way.
Russell has the adapters a pieces you. Got mine from Jegs.
Use -3 brake line.
Old 08-17-2011, 09:47 AM
cadeuces1's Avatar
2000 Tundra Limited 4X4. Need new steel brake lines to the rear. Can anyone tell me what diameter and connection thread/size I need?
Old 08-17-2011, 10:20 AM
skypilot's Avatar
5/16" should be a 3/8 10mm wrench. They all seem to have the same thread these days.
Old 08-18-2011, 10:11 AM
cadeuces1's Avatar
Thanks, skypilot! I appreciate the info.
Old 04-17-2012, 02:41 AM
AlexJet's Avatar
Good find for me, as I was looking for a thread size to rebuild my hard lines.
Old 04-17-2012, 09:57 AM
wyoming9's Avatar
Red face
You might want to double check.
My 2000 is 3/16" as well as all the older ones.
Old 04-17-2012, 10:27 AM
ogjohnboy's Avatar
i believe they were asking about the ferrule nuts not the tubing diameter.
09-04-2015 09:27 AM
87turboPA
07-12-2015 07:49 AM
crashburnoveride
07-10-2015 06:39 AM
87turboPA
07-09-2015 05:58 AM
Quick Reply: Brake line fitting Thread size.
