brake help 88 p/u
Old 11-30-2011, 10:13 PM
4wd4fun's Avatar
you said "i got home last night from work i pulled it into the garage and noticed my rear driver side tire was covered in fluid"
if fluid leaked from the cylinder enough to cover the tire there had to be some in the drum that contamintaed the pad / shoe. contaminated shoes can affect how brakes feel
sometimes they can swell some and make a touchy grabby pedal and sometimes they can make a soft pedal
Old 11-30-2011, 10:16 PM
runs-on-4's Avatar
oh well i cleans both my rear brakes out with brake part cleaner then used the air compressor to dry it and get all the fluid out. im gonna check the lspv tomorrow and re bleed it again..
Old 12-01-2011, 09:33 PM
runs-on-4's Avatar
fixing these brakes is a slow process do to lack of time, today i looked at my fsm about the lspv and it said if the lspv needs service take vehicle
to the dealer ship where it was purchased looks like i got some research to do on here
Old 12-06-2011, 09:11 AM
runs-on-4's Avatar
took my truck to a toyota specialist. yes they are still not fixed, i asked them about the lsvp and they said you cant really bleed it and it only thing it could affect is the amount of pressure applied to the back.. i guess im just gonna bleed and bleed and bleed. finally got some time 3 days off!!
Old 12-06-2011, 09:45 AM
  #25
93toyrunner2's Avatar
Have you replaced the leaking rear wheel cylinder or figure out why it leaked all over? You mentioned that you cleaned the brakes and parts, but did not say you had replaced the cylinder.
Old 12-06-2011, 09:50 AM
  #26
runs-on-4's Avatar
oh ya sorry i i replaced both of them actually
Old 12-06-2011, 11:23 AM
  #27
bassbro1's Avatar
You can bleed the lspv, and if it is rusted you won't have brakes in the rear. Whatever, keep searching I suppose.
Old 12-06-2011, 09:19 PM
  #28
4wd4fun's Avatar
runs-on-4:
PM sent. I'm near you.
greasyglue
12-12-2015 12:57 PM
1994Toyota4X2
08-22-2015 06:27 AM
Dennisx2
08-10-2015 06:48 AM
Dennisx2
08-04-2015 01:26 PM
Tyler Cunningham
07-11-2015 10:18 AM
Quick Reply: brake help 88 p/u
